ianmayco68 Posted June 15, 2018 Share Posted June 15, 2018 Hi all , finally changed my prop today ( should have done it earlier really ) for the one that James very kindly gave me on my 110 200tdi but they aren't the same . This is the one I took off and this is the one that James gave me off his project which was a 200tdi I believe and side by side the one I removed is a larger diameter tube , but both fit . I am presuming that the one James gave me is the correct one for a 200tdi 110 , so what vehicle is the one I've removed from my 110 for ? Or is that the correct one and the other is wrong . any Help but be appreciated . cheers Ian Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 15, 2018 Share Posted June 15, 2018 Yes. There were a variety of styles through the years. You just need to make sure you get the correct length as different gearbox arrangements use different length shafts. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 15, 2018 Share Posted June 15, 2018 The one James gave you is what they normally look like. The larger one looks more like a 130 prop. So assuming they are the same length then fit James's. Your original could be a cut down 130 one or just some sort of heavy duty one I haven't seen before. Mike Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted June 15, 2018 Author Share Posted June 15, 2018 Cheers both , have fitted James one , there was slight play in one of the yokes the hole was worn so it's scrap on the one I removed but was just curious what it was off . Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 16, 2018 Share Posted June 16, 2018 Glad it fitted. Was in use in my 110 before it was taken apart so should be a gooodun 👍 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted June 16, 2018 Author Share Posted June 16, 2018 Yes James thank you , been on a run to my mom & dads today 1hr each way and it was all good . Cheers Ian Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 16, 2018 Share Posted June 16, 2018 James, on the subject of props didn't you want one of mine? Off a 300Tdi 110 with Salisbury. Got the axle too Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 16, 2018 Share Posted June 16, 2018 Err... maybe! Apologies, memory like a sieve at the moment. I’ll send you a PM Quote Link to comment Share on other sites More sharing options...
