mmgemini Posted July 28, 2018 Share Posted July 28, 2018 I just carried two spare u/ j's easy enough to chane with a hammer and G clamp Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 4, 2018 Share Posted August 4, 2018 Last year when the hinges on my teng cases started to split... I looked for alternatives as the teng cases are not available on their own. I still wanted portability, and I like the set cases as you know when a tool is missing, misplaced when you’re packing up. So the Solution I went for was to pick up some Bosch tool boxes made by Sortimo and fit some foam inserts from shadow foam... I went for the 136 boxes, about £20-25 on eBay as they can fit two tool trays inside, but they’re available in numerous sizes. I got some ally plate bent up to size too, to hold the top shelf... You then have the laborious task of cutting out the foam with a scalpel, before they were ready... They are designed to stack on top of each other clipping in securely, and you can get some clips to secure the the first box to a shelf, floor etc. Sortimo does a bunch of other accessories, tray insert and boxes etc. although they’re quite pricey when buying them from Sortimo... https://www.sortimo.co.uk/shop/en_UK/BOXXes-%26-Cases/L-BOXX-family/c/47834?q=:tsa Theyve worked out well, very sturdy, stack well and as intended very portable. The only downside is if a tool breaks and you can’t get a like for like replacement your screwed unless you get out the scalpel again. 3 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 5, 2018 Share Posted August 5, 2018 That looks awesome Steve! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 5, 2018 Share Posted August 5, 2018 3 hours ago, landroversforever said: That looks awesome Steve! Ditto. Can't see where you've fitted your no. 1 tool 😉 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 5, 2018 Share Posted August 5, 2018 That’s a very good idea . Quote Link to comment Share on other sites More sharing options...
roamingyak Posted August 18, 2018 Author Share Posted August 18, 2018 Adding to the mix, I quite like this as its soft and can just be hung off of a couple of hooks for quick access. Downsides are there is nowhere to put smaller items like a 8mm, 10mm, 13mm, 17mm ratchet bits etc: Quote Link to comment Share on other sites More sharing options...
