Sean. Posted October 7, 2018 Share Posted October 7, 2018 Hello, I've had a very tight Defender TD5 2003 oil sump bolt removed by a garage, as it was wedged in. Tried all sorts, and they had to weld bolts on to get it off. Up shot is that it's leaking, I've taken it back and they have said bring it back, but it's time and fuel bringing it back over. I was looking to get an oversized oil sump bolt to replace it with. Helicoil I've heard mix things, and then when I come to change the oil next time I don't want to faffe about. I've read that the bolt is a M16, 16.5mm 1.5m thread, would the following Sealey set be the right thing to fix it with? Sealey VS617 Oil Drain Plug Thread Repair Set - M17 Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2018 Share Posted October 7, 2018 is it the actual sump drain plug thread or one of the bolts that secures the sump pan to the engine block ? if it is the drain plug, if it was my engine I would get another sump & drain plug. Quote Link to comment Share on other sites More sharing options...
Sean. Posted October 7, 2018 Author Share Posted October 7, 2018 It's the oil sump drain plug thread, and not a bolt secureing the pan to the engine block. Any brands for a new pan then, or would a second hand one of fleabay be ok? Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2018 Share Posted October 7, 2018 Any of the independent parts supplier would be able to get one, but you best sit down before looking at the price of a new sump https://www.brit-car.co.uk/product.php/101085/0/sump_pan_assy_td5_def_disco11 or from a engine being broken through ebay, some on ebay ---- https://www.ebay.co.uk/sch/i.html?_odkw=Land+Rover+Td5+sump+pan&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=Land+Rover+Td5+oil+sump+pan&_sacat=0 2nd hand would be fine BUT having a good look at it before buying would be a good idea, that thread kit you mentioned would work & be the cheapest option to fix your sump, but making sure it's re-tapped properly & sqaure to existing hole would be good too, I would suggest removing the sump to sort the thread out & then you can be sure there is no metal swarf left in sump. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 7, 2018 Share Posted October 7, 2018 (edited) come across stripped sump threads all the time at work. we have an oversized plug repair kit that always worked so far. m17x1.5 kit is what you need I believe, also doesnt require drilling. 👍 Edited October 7, 2018 by Landy-Novice 1 Quote Link to comment Share on other sites More sharing options...
Sean. Posted October 8, 2018 Author Share Posted October 8, 2018 Perfect, I'll try the kit, and see how I get on. Will fit it, and then drain it all out again, to ensure any fragments / swarf are washed out by the oil. Given aluminium is not magnetic. Worst case is to get a new sump 😖. Quote Link to comment Share on other sites More sharing options...
Sean. Posted October 12, 2018 Author Share Posted October 12, 2018 Well, the sealey kit is not ideal as the plug has a torx screw connection and not the 13mm bolt on top. I will see if I can find another kit with the bolt type on top, and if this one even fits! Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted October 12, 2018 Share Posted October 12, 2018 All you need to do is tap it out with a 3/8" BSP tap.Needs no drilling etc,then obviously a 3/8 bung. I use hydraulic fittings to do this,same as used for blanking hydraulic ports in spool blocks. Any Ag dealership or hydraulics place should have them on the shelf. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 12, 2018 Share Posted October 12, 2018 Another option might be to buy one of those Femco drain plug wotsits to fit the thread and chemical metal that in place. Then the oil changes are done through that mechanism. Quote Link to comment Share on other sites More sharing options...
