Yostumpy Posted November 16, 2018 Share Posted November 16, 2018 (edited) Can anyone tell me whether SPF000250 brake pads (gen LR) will fit 300tdi 110 '98, thanks. seem to be lots of different numbers. Edited November 16, 2018 by Yostumpy Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2018 Share Posted November 16, 2018 http://www.lrseries.com/shop/product/listing/11380/SFP000280-BRAKE-PAD-SET-REAR.html?search=stc1601&page=1 are 300tdi rear disc pads. the SPF000250 doesn't come up with anything on LRSeries or Brit-car websites. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted November 16, 2018 Author Share Posted November 16, 2018 (edited) sorry my bad, SFP 000250 says 2001 onwards,, but are they different? Edited November 16, 2018 by Yostumpy 1 Quote Link to comment Share on other sites More sharing options...
neil110 Posted November 16, 2018 Share Posted November 16, 2018 Yes, the pads changed when the Salisbury axle was replaced by the short nose axle. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted November 16, 2018 Author Share Posted November 16, 2018 ahh! ok thanks. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted November 17, 2018 Share Posted November 17, 2018 I have a 2002 (January) TD5 110 double cab and think LR were using production line stock up at the time. It has a 15P engine but as I found when doing the headgasket back in the summer it had plastic head dowels. Amoungst other things it has a Salisbury axle, but also has the front discs, larger calipers and larger pads on the back. So I think the change over was slightly earlier than the change to the short nose axle - so 2001 may be correct for the change over. Toby Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted November 17, 2018 Share Posted November 17, 2018 2 hours ago, Landrovernuts said: I have a 2002 (January) TD5 110 double cab and think LR were using production line stock up at the time. It has a 15P engine but as I found when doing the headgasket back in the summer it had plastic head dowels. Amoungst other things it has a Salisbury axle, but also has the front discs, larger calipers and larger pads on the back. So I think the change over was slightly earlier than the change to the short nose axle - so 2001 may be correct for the change over. Toby Well deduced! Calipers changed 614xxx chassis no., 2002 model year started 624xxx and the axle changed about 638xxx Quote Link to comment Share on other sites More sharing options...
