Tim2809 Posted December 28, 2018 Share Posted December 28, 2018 (edited) 1989 110 fitted with full 300tdi and r380 gearbox using all standard parts. . my clutch slips if weight of boot on clutch pedal, so when i changed gearbox i fitted another clutch and its still the same if not worse. changed master cylinder, slave and hose made no difference. master i even adjusted it to pull pedal down so return spring would pull rod back also tried with nuts loose and still the same loosened slave bolts right of to check if any pressure held against slave and all good. can push slave back into box easy by hand. have loosened bleed nipple and fluid drips out so not holding pressure anywhere now stumped any suggestions appreciated Edited December 28, 2018 by Tim2809 missing details Quote Link to comment Share on other sites More sharing options...
crwoody Posted December 28, 2018 Share Posted December 28, 2018 Did you replace the pressure plate as well? I was having problems with my clutch slipping recently but on fitting a new one the old friction plate was hardly worn, it was slipping due to the springs in the pressure plate not applying sufficient clamping pressure. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 28, 2018 Author Share Posted December 28, 2018 yes was complete 3 piece clutch Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 28, 2018 Author Share Posted December 28, 2018 that is almost what i feel could be the issue. 2 different make clutches and release bearings too. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 28, 2018 Author Share Posted December 28, 2018 wondering if the flywheel could cause issues? did not see any ridges or high spots Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 29, 2018 Share Posted December 29, 2018 On 12/28/2018 at 3:03 PM, Tim2809 said: also tried with nuts loose Commendable thoroughness.. anyway I believe there are 2 release bearings only slightly different in size, so maybe you have the longer one, and should have the shorter - we recently had someone on here with the opposite problem. It sounds like the clutch parts themselves are fine, so you are just missing a bit of clearance - that has to be the fork or the bearing, I can't see how anything else can affect it. Quote Link to comment Share on other sites More sharing options...
western Posted December 29, 2018 Share Posted December 29, 2018 If the main gearbox is a proper Defender spec R380, the clutch release bearing should be FTC4177, now UTJ100210, https://www.brit-car.co.uk/product.php/133759/0/clutch_release_bearing___defender its approx 10mm shorter than the FTC5200 bearing/carrier, I made that mistake a while ago & my 110 kept slipping, the shorter bearing cured it. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 29, 2018 Author Share Posted December 29, 2018 2 hours ago, western said: If the main gearbox is a proper Defender spec R380, the clutch release bearing should be FTC4177, now UTJ100210, https://www.brit-car.co.uk/product.php/133759/0/clutch_release_bearing___defender its approx 10mm shorter than the FTC5200 bearing/carrier, I made that mistake a while ago & my 110 kept slipping, the shorter bearing cured it. its a disco 300tdi with disco r380 and ashcroft selector adapter. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 29, 2018 Author Share Posted December 29, 2018 are disco r380 bearings same as defender? as im currently running the disco bearing paddocks list ftc5200 for both disco and defender 300tdi Quote Link to comment Share on other sites More sharing options...
western Posted December 29, 2018 Share Posted December 29, 2018 could be a incorrect release bearing still, not sure what Disco 300tdi uses. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 29, 2018 Author Share Posted December 29, 2018 its the bearing and fork out the disco i broke. it drove well without any slippage which is why im baffled Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 29, 2018 Author Share Posted December 29, 2018 weather permitting i will be pulling engine tomorrow. anyone know dimension of either bearing? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 30, 2018 Share Posted December 30, 2018 Better have a read of..Link Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 30, 2018 Author Share Posted December 30, 2018 9 hours ago, cackshifter said: Better have a read of..Link had a read. interesting but mine is not a stumpy r380. so confused even more. im pulling engine out now so will see. im going to takee slave off and measure rod protrution before splitting and try and measure where bearing sits and see it its restricted Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 30, 2018 Author Share Posted December 30, 2018 engine out and measured. pushrod protrudes 25mm out of slave hole. bearing has about 40mm of clearance at rear so does not appear to be binding. old gearbox had pushrod of 95mm length. replacement has 105mm rod. flywheel has no groves or high spots. checked finger height on clutch before removing and bolted to spare flywheel and both same height bearing face to slipper pad approx 35mm many thanks for all your suggestions so far. Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2018 Share Posted December 30, 2018 looking on lrparts/ru website it gives release bearing as FTC5200 for a Disco 300Tdi & R380 gearbox combination pushrod is FTC3912 it does not give rod length. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 30, 2018 Author Share Posted December 30, 2018 from hunting around i found i have the correct bearing and pushrod. i made 1 clutch up out of the 2 of the same make i have and initial feel is better. cannot get it to slip when trying to pull away with footbrake applied so fingers crossed Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 31, 2018 Share Posted December 31, 2018 That sounds promising. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted December 31, 2018 Author Share Posted December 31, 2018 i mo longer have clutch slip but if i do press clutch pedal abit more than riding the clutch it will slip. main thing is it wont slip and fully engages/disengages thanks everyone for all help and suggestions by rights i should now be bald 1 Quote Link to comment Share on other sites More sharing options...
