300Tdi Power Steering Pump - should it make a noise?
SPendrey
I've been chasing a rattling noise, replaced the water pump because there was play in the pulley.  Replaced the belt tensioner because it was weeping some sort of fluid (?).  The timing cover is less than a year old, but there is a rattle within the pulley/bearing.  However, the company I bought it from has gone bust, so no news there.
The power steering pump does make a clicking noise when turned in the direction it would operate, but no noise the other way.  Is this normal?  The attached video (with rather poor sound I'm afraid) should illustrate the noise, but it is more of a clicking than can be made out.  I'm thinking this is the next item for replacement?
As it is basically a small hydraulic pump I would expect it to be pretty quiet in operation,.   Is it high miles? ,.. It isn't something I have particular experience of  but I am sure someone will..........:unsure:
  • 2 weeks later...
I can report the replacement is in, and the noise is gone... but what I can't explain is why, having put the new pump in, the left hand wheel now rubs on the radius arm?!  Nothing in the geometry was changed, could it simply be there's more "power" pushing the steering box??
