Peterla Posted December 30, 2006 Share Posted December 30, 2006 I have notice in my RAVE manual it reccomneds new head bolts be fitted when the head hase been removed. Is this a over kill or is this something i should adhear to. Any comments would be appreciated. Peter Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 30, 2006 Share Posted December 30, 2006 I have notice in my RAVE manual it reccomneds new head bolts be fitted when the head hase been removed.Is this a over kill or is this something i should adhear to. Any comments would be appreciated. Peter acording to the LR manual you can reuse 200 tdi head bolts a maximum of 5 times as long as there not dammaged but if you don't know wether the heads been off before or how many times it might be worth a new set mike Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 30, 2006 Share Posted December 30, 2006 acording to the LR manual you can reuse 200 tdi head bolts a maximum of 5 times as long as there not dammaged but if you don't know wether the heads been off before or how many times it might be worth a new set mike My engine shop recomends new bolts as even if they have only been used the once before they have had premature gasket failures occur, but since using new bolts each time they have had no premature gasket failures. Quote Link to comment Share on other sites More sharing options...
Andy Posted December 30, 2006 Share Posted December 30, 2006 the bolts can streach with use, there is probably a way to check for this but i dont know what it is. i reused the bolts on my head & had no problems. on a previous car i did have a problem with streaching bolts though, only way i noticed was they felt wrong as i did them up - never to that 'last grunt & its tight' feeling. if that makes any sense. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 30, 2006 Share Posted December 30, 2006 the bolts can streach with use, there is probably a way to check for this but i dont know what it is. i reused the bolts on my head & had no problems.on a previous car i did have a problem with streaching bolts though, only way i noticed was they felt wrong as i did them up - never to that 'last grunt & its tight' feeling. if that makes any sense. Ah the human torque wrench "3 grunts on a 4 foot bar and she's a good 'un" Quote Link to comment Share on other sites More sharing options...
Peterla Posted December 31, 2006 Author Share Posted December 31, 2006 Thanks, As I have only had this car for six months and it has done 280,00 kilometers it seems like the best solution would be to use new bolts as it came with no history on repairs previously done. Pete Quote Link to comment Share on other sites More sharing options...
Andy Posted January 1, 2007 Share Posted January 1, 2007 Ah the human torque wrench "3 grunts on a 4 foot bar and she's a good 'un" well personally its 3 clicks of the elbow & stop Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 3, 2007 Share Posted January 3, 2007 Just to be difficult, we have had gasket failures after fitting new bolts. Oh well.... Quote Link to comment Share on other sites More sharing options...
T1G UP Posted January 3, 2007 Share Posted January 3, 2007 I've always used new bolts installed to required torque then ran it for a while, a few heat cycles, then re torqued. Quote Link to comment Share on other sites More sharing options...
