enen Posted March 30, 2020 Share Posted March 30, 2020 Chasing a clunk in the drivetrain, i found the splines on the output shaft of the gearbox worn. Unfortunate as this transfer case is the "G" model which has the uprated gear So gearbox needs to be torn apart. Might as well do clutch while box is out. Any recommendations on a clutch/friction plate? Anything else i should change now? Thank you Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 30, 2020 Share Posted March 30, 2020 Just a decent standard one would be good enough. Unless you're doing a lot of work in which case I'd go for an uprated one from Clutchfix. Quote Link to comment Share on other sites More sharing options...
enen Posted March 30, 2020 Author Share Posted March 30, 2020 Is Britpart still considered below par? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 30, 2020 Share Posted March 30, 2020 Personally, yes. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted March 31, 2020 Share Posted March 31, 2020 Generally, yes Sensibly, yes Logically, yes Go for a Valeo or Borg and Beck Quote Link to comment Share on other sites More sharing options...
enen Posted April 28, 2020 Author Share Posted April 28, 2020 Sorry to revive an old thread When i removed the PTO cover, I didnt see a nut on the main shaft holding the input gear (FTC5087) onto the shaft even though the shaft is threaded I cant see a nut for this in my parts manual Is there a nut holding this gear in place? Thank you Quote Link to comment Share on other sites More sharing options...
lo-fi Posted April 29, 2020 Share Posted April 29, 2020 There's no nut, the input gear is mounted in the transfer box in dual bearings. The threaded end on the LT77 mainshaft is not used in this application. Quote Link to comment Share on other sites More sharing options...
enen Posted April 29, 2020 Author Share Posted April 29, 2020 Great, thank you I wanted to make sure, hate doing things wrong, gets expensive Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 30, 2020 Share Posted April 30, 2020 On 4/28/2020 at 5:13 PM, enen said: Sorry to revive an old thread When i removed the PTO cover, I didnt see a nut on the main shaft holding the input gear (FTC5087) onto the shaft even though the shaft is threaded I cant see a nut for this in my parts manual Is there a nut holding this gear in place? Thank you I wouldn't call that a thread revival! It's got to be at least a couple of years for that, it's barely been a month! Steve Quote Link to comment Share on other sites More sharing options...
