kevin50 Posted April 12, 2020 Share Posted April 12, 2020 Starting to fit my Headliner, problems with the first bit at the front.ย All holes Just about line up but its still sagging in the middle.ย Thers plenty of room to get in from the back to Glue or maybe Velcro. but cant understand why it sags . Not sure if Ive missed somthing out or not.ย Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 12, 2020 Share Posted April 12, 2020 Are there not holes for fixing on that edge? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 12, 2020 Author Share Posted April 12, 2020 19 minutes ago, ballcock said: Are there not holes for fixing on that edge? Yes there are 4 holes but when clipped up and in to the roofย it sags in the middle Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 12, 2020 Share Posted April 12, 2020 The next section overlaps the section you've fitted then you put the fir tree clips through both sections into the roof brace , I'll get you a pic of my 110 tomorrow . If you look at your photo here , the piece that's first you fit over the driver , the second piece you fit next at the rear , the last piece is the middle section you fit that last , that overlaps the front and back sections which you fir tree clip through the two sections into the roof this stops them sagging , the rear two sections also clip down the center you shouldn't need glue or Velcro I'll get you a pic of my 110 tomorrow . Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted April 12, 2020 Share Posted April 12, 2020 1 hour ago, kevin50 said: Yes there are 4 holes but when clipped up and in to the roofย it sags in the middle That headliner you have is 26 years old at its newest, the board weakens with age and droops. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 12, 2020 Author Share Posted April 12, 2020 12 minutes ago, ianmayco68 said: The next section overlaps the section you've fitted then you put the fir tree clips through both sections into the roof brace , I'll get you a pic of my 110 tomorrow . If you look at your photo here , the piece that's first you fit over the driver , the second piece you fit next at the rear , the last piece is the middle section you fit that last , that overlaps the front and back sections which you fir tree clip through the two sections into the roof this stops them sagging , the rear two sections also clip down the center you shouldn't need glue or Velcro I'll get you a pic of my 110 tomorrow . Thanks Mate So fit the rear next then the centre last ? I notice that there is a hole in esch centre of other 2, pity there isn't one like that in the front one. One thing I have noticed whilst looking at pics is this box section for light, here on the front in this pic, I know there is a recess in the liner but it only really rests on to this box, thus leaving a large gap hence the sagging,ย Wonder ifย this might need cutting out as would make it press firm against the roof,ย Or Notย Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 12, 2020 Share Posted April 12, 2020 I've not seen one of those , the interior light probably screws through the light base through the liner and into that . Have you got the light to have a look ? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 10 hours ago, ianmayco68 said: I've not seen one of those , the interior light probably screws through the light base through the liner and into that . Have you got the light to have a look ? Im sure its somewhere, Problem with my rebuild is I bought it as a rolling chassis and boxes full of parts, some of them missing. Didn't take it apart Hence all Questions on how to put back together. ย ๐ Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 13, 2020 Share Posted April 13, 2020 Hahaha I took mine apart and I still canโt remember where stuff goes ๐๐๐๐๐๐ Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 13, 2020 Share Posted April 13, 2020 here you go the recess for the interior light is there but I fitted a MUD roof console so moved it forward. Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 The older glass covered interior light screws through he headliner & into that mounting plate, so when its fitted helps to keep the headliner in place. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 5 minutes ago, ianmayco68 said: here you go the recess for the interior light is there but I fitted a MUD roof console so moved it forward. Thanks. Gonna hunt my light out Im sure its there somewhere, not sure weather to cut round the box carefully to see if it stops Sagging, 2 minutes ago, western said: The older glass covered interior light screws through he headliner & into that mounting plate, so when its fitted helps to keep the headliner in place. Will try it up first Just thought will have to run wires from it to before finally putting all fixings in liner, which will be my next question, where to run them too.ย Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 Hers mine when I first got it Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 Quote The older glass covered interior light screws through he headliner & into that mounting plate, so when its fitted helps to keep the headliner in place. Will try it up first Just thought will have to run wires from it to before finally putting all fixings in liner, which will be my next question, where to run them too.ย the wires go along the roof to the right side internal gutter then down screen pillar to the dash switch between column & door. I may still have my old glass light, will have a look. ย Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 9 minutes ago, western said: the wires go along the roof to the right side internal gutter then down screen pillar to the dash switch between column & door. I may still have my old glass light, will have a look. ย Thanks Mate Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 Had a look Kev but haven't found it sorry.ย Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 Here's mine , there is only 1 wire coming from it, it seems to fit in the gap alright when offered up but don't think it will solve the Sag in middle once fitted. Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 IIRC it was earthed to the roof structure by one of the attachment screws. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 53 minutes ago, western said: IIRC it was earthed to the roof structure by one of the attachment screws. Right so do I just run the 1 wire down where you said to dash ? Thanksย Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 Got the rear one in it fits Good no Sag with having a clip right in the middle. Ran a wire from Light down to dash ready for later. Just waiting on some Velcro for front , then I will try the centre bit up. Also got the bit for top of back door. some other bits too not sure where they go as this used to beย 4 Door CSW, but its a Van now. 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 3 hours ago, kevin50 said: Right so do I just run the 1 wire down where you said to dash ? Thanksย Yes, that's how mine was wired. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 24 minutes ago, western said: Yes, that's how mine was wired. Thanks tried the wire to live then touched another to bolt and it worked. Is there a switch on the dash?, or in my case will there be as haven't got that far yet, my whole dash is waiting to be wired and built up yet. Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 one of the 3 rocker switches between column door controls the interior light. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2020 Author Share Posted April 13, 2020 2 hours ago, western said: one of the 3 rocker switches between column door controls the interior light. Thanks Mate Not sure where you mean but will come across them in good time. Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 Above your rigth knee when sat in driver seat.ย Quote Link to comment Share on other sites More sharing options...
