Cornish Rattler Posted June 11, 2020 Share Posted June 11, 2020 Hi guys Over the weekend we fitted a center gauge panel over the original center gauge panel which incudes a GPS speedo, a re-located boost gauge ( 200tdi ) a USB socket ( twin ) an EGT gauge and an LED Volt gauge, been waiting for the Volt gauge to arrive hence why i've just posted the thread Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted June 11, 2020 Share Posted June 11, 2020 Where did you get the GPS speedo from? Is it quick to attain a signal? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 11, 2020 Author Share Posted June 11, 2020 (edited) 1 hour ago, Chicken Drumstick said: Where did you get the GPS speedo from? Is it quick to attain a signal? Yes and off ebay just make sure its a multi voltage one goes from something like 5-36v a bacic 12V one may not work 🙂 Edited June 11, 2020 by Cornish Rattler Read post wrong Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 11, 2020 Author Share Posted June 11, 2020 1 minute ago, Cornish Rattler said: Yes and off ebay just make sure its a multi voltage one goes from something like 5-36v a bacic 12V one may not work 🙂 sory read your post wrong, yes just take a live feed from ignition switch and an earth then put the GPS senser somewhere Quote Link to comment Share on other sites More sharing options...
Landrover17H Posted June 12, 2020 Share Posted June 12, 2020 (edited) Should we be concerned? I mean, we care. It starts with something seemingly innocent, you know - a few gauges, in er... blue. A few weeks later it's a farm-jack. Then there's the f**k-off roof-rack. Next comes the slow creep of the umpteen jerry-cans. The mahoosive towel-rail for a football-stadium of spot-lights? A sheet of "I was never confused" chequer-plate - strictly to vertical-panels, mind... Finally comes 'The Hat'. You know the one. The signs are there. I worry, we worry. This can happen to anyone. We're a caring sharing lot here, we ask because we care. Lest we forget... The Gospel according to St. Phillip of Sterndale. Edited June 12, 2020 by Landrover17H 2 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 13, 2020 Author Share Posted June 13, 2020 Took the landy out for a run today to test the new gauges and they all worked fine and checked to see how fast it would go and it topped out at 90 mph but my cruising speed is 75 mph so quite pleased with that Quote Link to comment Share on other sites More sharing options...
jessejazza Posted June 13, 2020 Share Posted June 13, 2020 17 minutes ago, Cornish Rattler said: Took the landy out for a run today to test the new gauges and they all worked fine and checked to see how fast it would go and it topped out at 90 mph but my cruising speed is 75 mph so quite pleased with that 90 mph - gulp I've managed to make 60mph at best effort! I also have a GPS speedo - think we have the same model and I have been pleased with mine. I found the speedo cable securing screw had been sheared and so fitting a GPS speedo was the better option compared with taking out and dismantling the g'box to drill out the stud. I'm pleased with mine and will be fitting one to my kitcar build. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 13, 2020 Share Posted June 13, 2020 On 6/12/2020 at 7:47 AM, Landrover17H said: Should we be concerned? I mean, we care. It starts with something seemingly innocent, you know - a few gauges, in er... blue. A few weeks later it's a farm-jack. Then there's the f**k-off roof-rack. Next comes the slow creep of the umpteen jerry-cans. The mahoosive towel-rail for a football-stadium of spot-lights? A sheet of "I was never confused" chequer-plate - strictly to vertical-panels, mind... Finally comes 'The Hat'. You know the one. The signs are there. I worry, we worry. This can happen to anyone. We're a caring sharing lot here, we ask because we care. Lest we forget... The Gospel according to St. Phillip of Sterndale. 😂😂 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 23, 2020 Author Share Posted June 23, 2020 Mite look into getting a brighter GPS speedo as the one i have is quite dim in daylight but other than that everythings working great 🙂 Quote Link to comment Share on other sites More sharing options...
jessejazza Posted June 23, 2020 Share Posted June 23, 2020 12 hours ago, Cornish Rattler said: Mite look into getting a brighter GPS speedo as the one i have is quite dim in daylight but other than that everythings working great 🙂 Yes I also found that - rewired the light to permanent when ignition on. No problem then. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 25, 2020 Author Share Posted June 25, 2020 On 6/23/2020 at 11:17 PM, jessejazza said: Yes I also found that - rewired the light to permanent when ignition on. No problem then. Thats how its wired now but dim 🤨 Quote Link to comment Share on other sites More sharing options...
