white90 Posted January 10, 2007 Share Posted January 10, 2007 Changed motor still the same wheel boxes are not seized but turn freely lubed drive cable any suggestions? could it be the switch gear or is there a relay to do with the windscreen wipers? they seem to work fine if the glass is wet almost like too much drag when the glass is dry or drying Quote Link to comment Share on other sites More sharing options...
ciderman Posted January 10, 2007 Share Posted January 10, 2007 I think there is a relay but I think its for the intermitant wipe . Quote Link to comment Share on other sites More sharing options...
simonb Posted January 10, 2007 Share Posted January 10, 2007 Changed motor still the samewheel boxes are not seized but turn freely lubed drive cable any suggestions? could it be the switch gear or is there a relay to do with the windscreen wipers? they seem to work fine if the glass is wet almost like too much drag when the glass is dry or drying Relay in standard setup only affects int wipe, doesn't do anything on cont wipe. Since you have done all the obvious tap in a multimeter connection to the red/green wire at the motor end with it still connected to the wiper motor. Check you actually have 12v there with motor under load. You may have a high resistance feed (in the switch possibly) that measures 12v with no load but then drops to zero under load. Just had a similar problem on a heated rear window on a Citroen. 12v at the connector with it undone but nothing when it was connected. Ended up running a new wire from the dash to the tailgate to fix that one. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 10, 2007 Share Posted January 10, 2007 Bad earth? ISTR they are earthed through a small braided strap to the bulkhead or similar. Quote Link to comment Share on other sites More sharing options...
JST Posted January 10, 2007 Share Posted January 10, 2007 dont use them when the screen dry! (mine are the same!) as usual no help to anyone! Quote Link to comment Share on other sites More sharing options...
western Posted January 10, 2007 Share Posted January 10, 2007 Same as mine, they drag on a dry screen. Quote Link to comment Share on other sites More sharing options...
