Cchase Posted March 6, 2021 Share Posted March 6, 2021 Working on The Tramp this week and found this little surprise waiting for me. No wonder the wheel wouldn't turn when the hub was locked! The teeth on the inner end of the halfshaft look fine, but I guess I need to have a close inspection of the diff? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 6, 2021 Share Posted March 6, 2021 7 hours ago, Cchase said: Working on The Tramp this week and found this little surprise waiting for me. No wonder the wheel wouldn't turn when the hub was locked! The teeth on the inner end of the halfshaft look fine, but I guess I need to have a close inspection of the diff? Wow thats not good ☹️ Quote Link to comment Share on other sites More sharing options...
Cchase Posted March 6, 2021 Author Share Posted March 6, 2021 I have a Stage 1 parts donor. Is there anything to prevent me from using the halfshafts, 'knuckles' and stub axles from it (and brakes) on the 109? Thanks, C Quote Link to comment Share on other sites More sharing options...
Daan Posted March 7, 2021 Share Posted March 7, 2021 The stage 1 has CV's, but you can use them. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 7, 2021 Share Posted March 7, 2021 On 3/6/2021 at 10:28 AM, Cchase said: I have a Stage 1 parts donor. Is there anything to prevent me from using the halfshafts, 'knuckles' and stub axles from it (and brakes) on the 109? Thanks, C Why not use the whole axle? I have a feeling they might've gotten 4-pin front diffs - the Stage 1 are higher ratio for nicer cruising too but you'd have to swap in the back axle too to keep the ratios matched. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 8, 2021 Share Posted March 8, 2021 As John said, it may be better to swap the whole axle over, though I wouldn’t recommend the 3,54 diffs unless you have a significant engine upgrade. You should be able to swap the diff with the existing axle, though. I’d be very wary of the current axle. It looks like the UJ yolks have been smashing against the swivel pun bearings or Railko bush housing, so they may also be damaged, and to have come into contact with those, the shaft must have been flailing, so the swivel housing and stub axle bearings must be shot to pieces. You have a lot more than just the shaft to replace. Pretty spectacular, though. 1 Quote Link to comment Share on other sites More sharing options...
