300Tdi Cylinder Head - Bush
Hi Folks,
Trying to understand part 22 in the following diagram shamelessly copied from LRworkshop. Defender 300 Tdi 1997
It's described as a bush. Any thoughts? Do not recall coming across this when pulling apart our cylinder head.
Thanks,
Simon...
29 minutes ago, reb78 said:
Its just a spacer isnt it? presumably so the lifting eye sits flat across bits of the head that are not flat??
That was my first thought also. However, the lifting eye goes across the back on our cylinder head flat. Perhaps a spacer for slightly different types of cylinder head?
The part number appears to be 390939 and can be described as 'METAL BUSH - MULTI USE - DEFENDER - DISCOVERY 1 - RANGE ROVER CLASSIC (PACK OF 5)'.
To support the 'multi-use' element, Craddocks describe it as 'Roller for Seat Slide Range Rover and Discovery and 90/110'.
 I have just recalled that if you search LRW by part number it shows an alternative use, as a spacer underneath the nut of a 'nut and bolt' holding a wiring P clip in place; presumably so that a socket can be mounted on the nut without fouling the P clip.
The point here is that there is a P clip included on the original drawing of the lifting eye.
Regards.
Edited by David Sparkes
To add details of the P clip use.
