Adrian Huntley Posted June 28, 2021 Share Posted June 28, 2021 Can you get a hub reducers to put landrover discovery 2 wheels to fit a landrover discovery 3 ? Many thanks Adrian Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 29, 2021 Share Posted June 29, 2021 do you mean spigot rings to reduce the centre bore of the wheel to suit? Quote Link to comment Share on other sites More sharing options...
missingsid Posted June 29, 2021 Share Posted June 29, 2021 Are D2 wheels rated for a D3, aren't D3s heavier? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 29, 2021 Share Posted June 29, 2021 10 hours ago, RedLineMike said: do you mean spigot rings to reduce the centre bore of the wheel to suit? Spigot rings in this case are for the other way round. Putting D3 wheels onto a D2. I've not seen anything to go the other way but would be doable with a custom spacer. As above though, I'd be concerned about the weight of a D3. D2 MGW is 2880Kg, D3 MGW is about 3200kg from memory so depending on what axle weights the D2 wheels are rated for, they won't be high enough for a D3. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted July 9, 2021 Share Posted July 9, 2021 Discovery 2 Kerb weight os 2061 to 2220kg Discovery 3 Keb Weight 2394kg Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 9, 2021 Share Posted July 9, 2021 It's the MGW and Axle weights more specifically that will matter Quote Link to comment Share on other sites More sharing options...
