Bigwood Posted January 17, 2007 Share Posted January 17, 2007 Now my 90 is back on the road I am starting to get the things working that didnt work when I bought it . My next task is the heated rear window !. When you switch it on the oil warning light comes on as well as the rear window light. I have tried the modification to the voltage sensing relay as suplied by White 90 sometime back , I only did this to try and see iff it made a difernce. I am shure I have an earth fault, any clues would shorten the agro of this little problem. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 17, 2007 Share Posted January 17, 2007 Do you have a wiring diagram? That should give you a few clues. Quote Link to comment Share on other sites More sharing options...
simonb Posted January 17, 2007 Share Posted January 17, 2007 Now my 90 is back on the road I am starting to get the things working that didnt work when I bought it . My next task is the heated rear window !. When you switch it on the oil warning light comes on as well as the rear window light. I have tried the modification to the voltage sensing relay as suplied by White 90 sometime back , I only did this to try and see iff it made a difernce. I am shure I have an earth fault, any clues would shorten the agro of this little problem. With a voltmeter, measure which connector on the element is at +12v. Run a temporary new wire from THE OTHER terminal back to battery negative. If this cures the problem its an earth fault at the rear door end. IIRC Land Rover just earthed the element to the door frame, which is not only a cr*p arrangement but will aslo make the ally/steel corrosion even worse. If this temp fix works, then make a permanent earth connection from the element either i) to rear body via loop of wire across from door. ii) to earth on rear lights via brake/indicator earth iii) back to battery negative iii) is best option If this doesn't cure it fault is at switch, VSR end. I persume the VSR need an earth connection to measure volts??? Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2007 Share Posted January 17, 2007 This rear screen heater wiring diagram might help Quote Link to comment Share on other sites More sharing options...
phil37 Posted December 1, 2007 Share Posted December 1, 2007 This rear screen heater wiring diagram might help Hi can anyone tell me where i can find number 1 on the above please. Regards Phil Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2007 Share Posted December 1, 2007 item 1 above lives on the cab side of the bulkhead behind the 3 switch panel [right of steering wheel] it's a largish yellow relay, also move the instrument pack towards the steering wheel to assist access/vision into the right forward corner, the rear heated screen relay sits next to it. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 2, 2007 Share Posted December 2, 2007 You can do away with the voltage sensing relay if it's faulty, there's a "how to" in the tech archive. HTH Mo Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 2, 2007 Share Posted December 2, 2007 You can do away with the voltage sensing relay if it's faulty, there's a "how to" in the tech archive.HTH Mo IIRC they were only fitted to vehicles with a small alternator, about 55amps i think., later vehicles with the "big" 70a didnt have them. my original 200Tdi 90 had one, when i upgraded the alternator, i just unplugged the voltage relay, and with a small length of beefy wire (with a male spade crimped onto each end) joined the two main power cables in the socket together, thus leaving the rear window under my control. Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2007 Share Posted December 2, 2007 my 110 had a 65amp alt, it's got one & still has with the 100amp alt fitted, been no trouble over the last 8 years since the 100amp alt's been fitted Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 2, 2007 Share Posted December 2, 2007 thus leaving the rear window under my control. I had no idea that you were such a control freak, Ralph Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2007 Share Posted December 2, 2007 I had no idea that you were such a control freak, Ralph Mo Not me, that was in Diesel_Jim's reply not mine Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 2, 2007 Share Posted December 2, 2007 Not me, that was in Diesel_Jim's reply not mine Yup, I knew that ...... I'm off Mo Quote Link to comment Share on other sites More sharing options...
