Qhriss Posted August 20, 2021 Share Posted August 20, 2021 Well, after a run out , oil filter seal let go massively , on Staines bypass ( how appropriate .... ) , had fitted new filter and seal few months ago by the way . Bought new filter kit with seal but would like part number or source for seal only . Many thanks . Q Quote Link to comment Share on other sites More sharing options...
western Posted August 20, 2021 Share Posted August 20, 2021 is it a later modern style one part filter or the older element that goes in a outer canister, if the old style filter the seal is 272539 from my 110 2.25 petrol engine parts book Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 20, 2021 Share Posted August 20, 2021 5 hours ago, western said: is it a later modern style one part filter or the older element that goes in a outer canister, if the old style filter the seal is 272539 from my 110 2.25 petrol engine parts book Oil Filter - 2.25 Litre Petrol - Find Land Rover parts at LR Workshop 1 Quote Link to comment Share on other sites More sharing options...
Qhriss Posted August 21, 2021 Author Share Posted August 21, 2021 15 hours ago, western said: is it a later modern style one part filter or the older element that goes in a outer canister, if the old style filter the seal is 272539 from my 110 2.25 petrol engine parts book The older paper element inside the cannister . Many thanks mate . Q Quote Link to comment Share on other sites More sharing options...
western Posted August 21, 2021 Share Posted August 21, 2021 Lets hope the new seal cures the problem, just another thought is the outer canister in perfect condition, not bent or dented around the sealing surface. Quote Link to comment Share on other sites More sharing options...
Qhriss Posted August 23, 2021 Author Share Posted August 23, 2021 On 8/21/2021 at 2:10 PM, western said: Lets hope the new seal cures the problem, just another thought is the outer canister in perfect condition, not bent or dented around the sealing surface. Well, did check it fr smoothness , it hasn't leaked in years , then started leaking after 3 months after changing the element Q Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 23, 2021 Share Posted August 23, 2021 You did remove the old one, yes? Quote Link to comment Share on other sites More sharing options...
Qhriss Posted August 25, 2021 Author Share Posted August 25, 2021 On 8/23/2021 at 5:43 PM, Gazzar said: You did remove the old one, yes? Yup- was compacted in the groove . New seal in - then 3months failed order 3 more in case the original was faulty . Q Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 25, 2021 Share Posted August 25, 2021 Dry fit the canister, ensure it seats into the groove. then fit the seal. A smear of oil on the canister will leave a witness mark, so you'll know if it's not secure. 1 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted August 31, 2021 Share Posted August 31, 2021 If being used regularly surely the spin on conversion using a 2.5NA filter housing is worth fitting? 1 Quote Link to comment Share on other sites More sharing options...
