Spring rates
Cornish Rattler
43 minutes ago, steve b said:
Diesel
F right 273lb/in free camber 5.625"
F left 203lb/in free camber 5.125"
R right 166lb/in free camber 7.42"
R left 166lb/in free camber 6.75"
Standard factory spec'sĀ
SteveĀ
Cheer's steve, would you know whst they are for parabolicsĀ šŸ™‚
3 hours ago, steve b said:
......in theory the same to give similar ride height and qualityĀ Ā
Ok, since fitting the roof tent and boarding the back out i've noticed the back a bit low which i half expected so was thinking of replacing them for new std springs, the landy doesn't off road.
How much weight do you think you've added?Ā
If within the normal load rating for an 88 then std. springs will workĀ
Jones springsĀ  , all other suppliers are variable . They can advise if you need something non std.
Ā
Steve
Despite sitting lower than when empty, is it actually too low? I think I'd be looking forward to the softer ride afforded by carrying a bit of weight.
I recall the TIC parabolics I had on my 88" were quite spine-jarring.
Ā
Steve
I'd say about 80-85kg
