giacomo.m Posted October 3, 2022 Share Posted October 3, 2022 Hi all, Defender Puma 110 2.4 Tdci 2010, since I have a problem with disengaging the central differential lock, and on the LT230T transfer it seems to me that there is no plug securing differential lock detent spring an ball, I wanted to know how to adjust the exact engagement and disengagement of the differential lock selector shaft ... thank you Giacomo Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted October 5, 2022 Author Share Posted October 5, 2022 Hi, 50 views and no answers, too technical question even for experts .....? however to be more precise the transfer is: LT230QRS thank you Giacomo Quote Link to comment Share on other sites More sharing options...
western Posted October 5, 2022 Share Posted October 5, 2022 I would suggest the diff lock adjustment with box fitted is limited to the diff lock light switch. as the diff lock mechanism cannot be accessed with the box fitted to the vehicle. similar to previous versions. as the main gearbox stops access to some of the cover plate bolts. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 5, 2022 Share Posted October 5, 2022 Having disassembled and reassembled one very recently, I just did it by feel. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 5, 2022 Share Posted October 5, 2022 Sorry, assumed you meant hi-lo, diff lock detent is as follows: Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted October 5, 2022 Author Share Posted October 5, 2022 Thank you Bowie69, but on that transfer there is no hole for detent plug and detent ball and spring.... Giacomo Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 5, 2022 Share Posted October 5, 2022 I'm sorry, I don't follow what you mean.... Quote Link to comment Share on other sites More sharing options...
Junglie Posted October 5, 2022 Share Posted October 5, 2022 2 hours ago, giacomo.m said: Thank you Bowie69, but on that transfer there is no hole for detent plug and detent ball and spring.... Giacomo Ciao Giacomo, In this picture the plug for the detent ball should be just out of sight behind the brass connector here: At least I think so from the diagram... Cheers, Simon Quote Link to comment Share on other sites More sharing options...
Peaklander Posted October 6, 2022 Share Posted October 6, 2022 This might help too... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 6, 2022 Share Posted October 6, 2022 What's part #19? https://www.lrworkshop.com/diagrams/land-rover-defender-transfer-box/transfer-box-lt230/front-housing_45148 And part 13/14/15: https://www.lrworkshop.com/diagrams/land-rover-defender-transfer-box/transfer-box-lt230/front-ouput-shaft_45149 Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted October 6, 2022 Author Share Posted October 6, 2022 Thank you all, I also thought it was there like the vast majority of Transfer LT230s, but I assure you it is not there if I can I take another more detailed photo Giacomo Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted October 6, 2022 Author Share Posted October 6, 2022 I confirm what I wrote Giacomo Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 7, 2022 Share Posted October 7, 2022 Your pictures don't show that area behind the switch? A flush fitted grub-screw covered in mud is very easy to miss. Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted October 7, 2022 Author Share Posted October 7, 2022 No no I can assure you it's not there I saw very well when the transfer was mounted Giacomo Quote Link to comment Share on other sites More sharing options...
