OT - electric turbo charger article
monkie
As used in F1 for several years. the main advantage is that instead of opening the wastegate, you can use the excess power generated to charge the hybrid battery.
Still, a shame they haven't been able to make a VNT turbo work on a petrol engine reliably. That would probably be a better solution.
Daan
