Manursr Posted May 10, 2023 Share Posted May 10, 2023 Hello everyone, New on the forum I just bought a 110 double cab pick up 2008 puma TD4 2.4 Spectre replica. I'm from Belgium near France border of Lille. Awesome car but with some technical problem. Does somenone has the size and/or model of the lower roller bearingof the steering column? Mine is literally missing and I would like to order one before to disassamble everything Quote Link to comment Share on other sites More sharing options...
TSD Posted May 10, 2023 Share Posted May 10, 2023 On my late 300tdi (so '98), the lower bearing was the lower bearing was 22.5mm id, 35.7mm od, 9.5mm wide, and marked INA F-49273.2 I don't know if the bearing is the same in the various different columns (at least 3 different part numbers). There was a change around 2008, but I would guess there's a decent chance the bearing is the same size. Quote Link to comment Share on other sites More sharing options...
Manursr Posted May 10, 2023 Author Share Posted May 10, 2023 Thanks for your reply! Is already the steering coumn on a 300 TDI a 48 spines? Quote Link to comment Share on other sites More sharing options...
TSD Posted May 10, 2023 Share Posted May 10, 2023 Quote Link to comment Share on other sites More sharing options...
Dev90 Posted November 6, 2023 Share Posted November 6, 2023 On 5/10/2023 at 9:36 AM, TSD said: On my late 300tdi (so '98), the lower bearing was the lower bearing was 22.5mm id, 35.7mm od, 9.5mm wide, and marked INA F-49273.2 I don't know if the bearing is the same in the various different columns (at least 3 different part numbers). There was a change around 2008, but I would guess there's a decent chance the bearing is the same size. These are not accurate measurements for that bearing I have stripped a few columns and now come up with a solution that’s viable Quote Link to comment Share on other sites More sharing options...
TSD Posted November 7, 2023 Share Posted November 7, 2023 10 hours ago, Dev90 said: These are not accurate measurements for that bearing I have stripped a few columns and now come up with a solution that’s viable Why not help out by posting the accurate measurements then? Quote Link to comment Share on other sites More sharing options...
Dev90 Posted November 7, 2023 Share Posted November 7, 2023 I’ll make the bushes available there’s nothing comercially out there I’ve made them Quote Link to comment Share on other sites More sharing options...
muzaz Posted November 7, 2023 Share Posted November 7, 2023 13 hours ago, Dev90 said: These are not accurate measurements for that bearing I have stripped a few columns and now come up with a solution that’s viable The bearing is imperial size 0.875" by 1.406" The older column part no is 22x36 2RS. Managed to order 22x36x9.5mm bearing from a local supplier. When I get them if they fit will share the make and part no. 1 1 Quote Link to comment Share on other sites More sharing options...
TSD Posted November 7, 2023 Share Posted November 7, 2023 also Quote Link to comment Share on other sites More sharing options...
Dev90 Posted November 7, 2023 Share Posted November 7, 2023 (edited) EBay item number 225861547541 https://www.ebay.co.uk/itm/225861547541?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qAND68I_S0q&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY Edited November 8, 2023 by western Clicky link added Quote Link to comment Share on other sites More sharing options...
hurbie Posted November 11, 2023 Share Posted November 11, 2023 so , i'm in the same boat now , while removing the steering wheel from the French donor for the Eurover project , the lower bearing fell apart . so i'm on the hunt for a bearing also ... i e-mailed https://parts.jaguarlandroverclassic.com to see if they can supply us with the right make and model (or a bearing ...) , not much hope on a decent outcome , but you never know .... Quote Link to comment Share on other sites More sharing options...
Dev90 Posted November 11, 2023 Share Posted November 11, 2023 1 hour ago, hurbie said: so , i'm in the same boat now , while removing the steering wheel from the French donor for the Eurover project , the lower bearing fell apart . so i'm on the hunt for a bearing also ... i e-mailed https://parts.jaguarlandroverclassic.com to see if they can supply us with the right make and model (or a bearing ...) , not much hope on a decent outcome , but you never know .... See the link above mate I’ve been making the bushes on eBay Quote Link to comment Share on other sites More sharing options...
hurbie Posted November 11, 2023 Share Posted November 11, 2023 1 hour ago, Dev90 said: See the link above mate I’ve been making the bushes on eBay i'm not in for a DIY bush replacement , i just want a decent bearing .... Quote Link to comment Share on other sites More sharing options...
muzaz Posted November 11, 2023 Share Posted November 11, 2023 2 hours ago, hurbie said: i'm not in for a DIY bush replacement , i just want a decent bearing .... Will let you know if the bearing I ordered is any good. Might be a couple of weeks tho as it's on order. 1 Quote Link to comment Share on other sites More sharing options...
Dev90 Posted November 12, 2023 Share Posted November 12, 2023 15 hours ago, hurbie said: i'm not in for a DIY bush replacement , i just want a decent bearing .... Probably better off just buying a column then as from what I found it was a special bearing not available Quote Link to comment Share on other sites More sharing options...
hurbie Posted November 12, 2023 Share Posted November 12, 2023 50 minutes ago, Dev90 said: Probably better off just buying a column then as from what I found it was a special bearing not available or a off the shelf bearing with "speedsleave's" to make them fit . Quote Link to comment Share on other sites More sharing options...
muzaz Posted November 12, 2023 Share Posted November 12, 2023 2 hours ago, Dev90 said: Probably better off just buying a column then as from what I found it was a special bearing not available We'll see about that, I ordered a couple of 22x36x9.5mm bearings from my local bearing shop which may be the right ones. Quote Link to comment Share on other sites More sharing options...
muzaz Posted November 12, 2023 Share Posted November 12, 2023 2 hours ago, hurbie said: or a off the shelf bearing with "speedsleave's" to make them fit . Doubt you'll find any that fit without machining the steering shaft. Closest commercialy available bearings I found is 20x32x10mm Quote Link to comment Share on other sites More sharing options...
hurbie Posted November 12, 2023 Share Posted November 12, 2023 i seem to have found the one 🙂 from my measurements i have this : outside 35.8mm or 1.40" (1 13/32") don't know if this is the correct translation inside 22.2 or 0.87" (7/8" ) this is the shaft size , not the inside off the bearing) thickness 9.6mm 0.37" (3/8") and after a long time googling i found this : https://www.ebay.ca/itm/153998864061 if you scroll down the bottom it state's the size's in inches and they seem to match . way to expensive , so i keep hunting 🙂 1 Quote Link to comment Share on other sites More sharing options...
muzaz Posted November 12, 2023 Share Posted November 12, 2023 The size seems right, but as you said, expensive. The pair I ordered were 15€ each, still expensive for what they are but better than a complete column, just hope they fit. Once I get them, I'll update you if they fit properly and the part no 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted November 13, 2023 Share Posted November 13, 2023 (edited) got an answer from Landrover , not much use "Landrover never serviced the bearing seperatly" on my question who made the steeringshaft's the answer was "not allowed to share supplier information" so , not much help. the good news is that a replacement column is still availeble : QMB101620 Edited November 13, 2023 by hurbie Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted November 13, 2023 Share Posted November 13, 2023 3 hours ago, hurbie said: "not allowed to share supplier information" for a car which is out of production 🤭 Quote Link to comment Share on other sites More sharing options...
Dev90 Posted November 14, 2023 Share Posted November 14, 2023 19 hours ago, hurbie said: got an answer from Landrover , not much use "Landrover never serviced the bearing seperatly" on my question who made the steeringshaft's the answer was "not allowed to share supplier information" so , not much help. the good news is that a replacement column is still availeble : QMB101620 The original bearing is made by ina but it’s not listed anywhere at all Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2023 Share Posted November 14, 2023 Just a thought how is the inner column on Series vehicles held so it can rotate, Anyone looked if it's bearings or bronze oiled bushes? Quote Link to comment Share on other sites More sharing options...
hurbie Posted November 14, 2023 Share Posted November 14, 2023 1 hour ago, western said: Just a thought how is the inner column on Series vehicles held so it can rotate, Anyone looked if it's bearings or bronze oiled bushes? bearing cup and steel balls , so doubt it wil work . Quote Link to comment Share on other sites More sharing options...
