bishbosh Posted June 13, 2023 Share Posted June 13, 2023 Has anyone successfully attached one of these 370 x 185mm Plastic Frame Net – MUD-UK (mudstuff.co.uk) to their headlining? If so, what type of fixing did you use please? I am assuming the fixings are only in the headlining and not into any of the roof ribs. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 14, 2023 Share Posted June 14, 2023 I On 6/13/2023 at 3:56 PM, bishbosh said: Has anyone successfully attached one of these 370 x 185mm Plastic Frame Net – MUD-UK (mudstuff.co.uk) to their headlining? If so, what type of fixing did you use please? I am assuming the fixings are only in the headlining and not into any of the roof ribs. I did many years ago Bish, big washers on the back, they were fine 👍 Mo Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 15, 2023 Author Share Posted June 15, 2023 Thanks Mo. I was hoping to find some wonder fixing that removed the need to lower the headlining but it seems I am being over optimistic! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 15, 2023 Share Posted June 15, 2023 Depending on where you want them, can you line up the fixing with the ribs? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 15, 2023 Share Posted June 15, 2023 Have you considered some of the slimmer plasterboard fixings? Rawlplug R-TAP-IT Plasterboard Fixing 10.5 x 30mm | Toolstation You'd need shorter screws I would think, but may work? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 15, 2023 Share Posted June 15, 2023 Or Jack nuts? Jack Nuts | Shop4Fasteners Would need a setting tool as well, but could be enough, depends on how structural feeling the headliner is. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 15, 2023 Share Posted June 15, 2023 2 minutes ago, Bowie69 said: Or Jack nuts? Jack Nuts | Shop4Fasteners Would need a setting tool as well, but could be enough, depends on how structural feeling the headliner is. that's a good shout for something like the headlining! Quote Link to comment Share on other sites More sharing options...
Junglie Posted June 15, 2023 Share Posted June 15, 2023 Wouldn't necessarily need the setting tool - use a longer than needed bolt to pull it in, then revert to the shorter one for actual fitting. A bit laborious perhaps, but isn't everything Landy related? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 15, 2023 Share Posted June 15, 2023 3 minutes ago, Junglie said: Wouldn't necessarily need the setting tool - use a longer than needed bolt to pull it in, then revert to the shorter one for actual fitting. A bit laborious perhaps, but isn't everything Landy related? yeah, you can set them with just some nuts. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 15, 2023 Share Posted June 15, 2023 Was more concerned about putting a dint in the roof, hence the suggestion of tool. Quote Link to comment Share on other sites More sharing options...
Junglie Posted June 15, 2023 Share Posted June 15, 2023 2 hours ago, Bowie69 said: Was more concerned about putting a dint in the roof, hence the suggestion of tool. Makes sense. Hadn't thought of that... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 15, 2023 Share Posted June 15, 2023 Should be OK with the bolt/nuts method. Win a nut most of the way onto a long enough bolt, wind the bolt in just enough, and holding that still with a spanner tighten the nut. Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted June 15, 2023 Share Posted June 15, 2023 4 hours ago, Bowie69 said: Or Jack nuts? I like those, never seen them before, its amazing what exists that you've never seen let alone know what they are called🤣 Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 16, 2023 Author Share Posted June 16, 2023 Jack nuts look good - I had considered the equivalent plasterboard fixing but they are much deeper so these look good! Thanks. 1 Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 16, 2023 Author Share Posted June 16, 2023 21 hours ago, landroversforever said: Should be OK with the bolt/nuts method. Win a nut most of the way onto a long enough bolt, wind the bolt in just enough, and holding that still with a spanner tighten the nut. This only works if you can stop the fixing spinning which as these don't have any tangs (like the plasterboard versions) may prove to be difficult. I have a tool for setting the plasterboard ones so should be good to go. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 16, 2023 Share Posted June 16, 2023 48 minutes ago, bishbosh said: This only works if you can stop the fixing spinning which as these don't have any tangs (like the plasterboard versions) may prove to be difficult. I have a tool for setting the plasterboard ones so should be good to go. It does work, same as doing a rivnut without the proper tool. Quote Link to comment Share on other sites More sharing options...
Algarvedave Posted July 25, 2023 Share Posted July 25, 2023 Depends where you are sticking it. Double sided sticky pads would work onto metal surfaces. Quote Link to comment Share on other sites More sharing options...
