P38 EAS faulty compressor?
19 minutes ago, geoffbeaumont said:
Bridging the relay shouldn't work if it's the thermal switch? The problem has to be external to the pump itself.
From that diagram it looks like the pump overheat switch signals the ECU so bridging the relay out would bypass that and force the motor to run.
If it's just the temp switch that is likely an easy fix too.
Precisely.
The temp switch is inside the pump, though. But I do believe it can be fixed. Or bridged...
Ah...helps when I'm not on a phone and can see the diagram properly... :wacko:
On 8/21/2023 at 10:22 AM, P38 Paul said:
Hi all, I have a EAS compressor that doesn't run unless I bridge the relay terminals, where do I start looking for the fault to get it working as it should?
A quick update, I bridged the compressor last night & when it started lifting I swapped the bridge wire for the relay & it kept running to full pressure then cut out as it should, went to the car this morning & its not working again.
Have you tested any of the connections shown in the circuit diagram - is the relay coil being fed 12v from the ECU (C176-1), is the overheat switch grounded or open circuit (C151-2), does it work if you put a different relay in?
I'm not familiar with the whole system / circuit so worth a read of the RAVE manual to understand how it works - I assume there's a pressure switch in there too.
Hi Fridge, you are talking to a complete idiot here, the only thing I can say at the moment is that I have tried multiple relays so I think I can rule the relay out.
OK so looking at the diagram;
The relay has a green wire to activate it from the ECU so that should get 12v when the ECU wants to switch the compressor on. The black wire (coil ground) should be a good earth (~zero ohms resistance from that wire to ground).
The black/purple wire from the compressor is for the overheat switch, it looks like that should normally be grounded (~zero ohms resistance from that wire to ground).
There's also the wires for the pressure switch inside the valve block and what looks like a shutoff timer or relay and an "air suspension inhibit switch" X209 - Electrical troubleshooting manual is here - Page 308 on is the EAS system including full circuit diagrams.
As above, most likely suspect is the thermal switch in the compressor. The thin black/purple wire on the compressor connector should have continuity to the ground (i.e. the thick black wire in the same connector). If it doesn't, the switch has failed. They can be replaced (new ones are available to solder in) or bridged. Simply ground the BP wire and see if the compressor runs as a first test. It's unlikely to be the ECU, unless there is a fault, which should be indicated on the dash. Pressure switches are often replaced, but rarely the cause.
  • Like 1
  • 3 weeks later...
I have just tried two more compressors & none of them are working until the relay is bridged, one of the compressors was removed from my car working two years ago just needing a new piston ring so I think that rules out a compressors being at fault.
Still sounds like the relay or what triggers the relay then.
Back to the question from a few posts up - do you see volts across the relay coil terminals when you're expecting it should be triggered?
Hi Fridge, the compressor is intermittent, when it doesn't run there is no voltage across the relay coil terminals, when it decides to run I have got 14v across the coil, its got to be whatever triggers the relay that is at fault but what am I looking for or where am I supposed to be looking?
PS, The black/purple wire from the compressor is grounded all of the time.
23 minutes ago, elbekko said:
Indeed probably the ECU deciding to not run the compressor, then. Do you have an EAS cable to connect a computer to the car?
Yes, I have the cable that connects to the Nanocom.
You seem to have ruled out the compressor. The ECU's rarely fail, I've only seen one in 15 years or so, but it can happen. It could be something simple as a bad connection in the wiring. Not always easy to find, unfortunately. The wire triggering the compressor relay is a green one, straight from the ECU (pin 8 ) to the relay.
51 minutes ago, elbekko said:
Any faults logged? If it's refusing to start the compressor for a reason, that reason should result in a fault.
There are a few faults logged on the Nanocom which I presume are from the none triggering compressor, they all come up as "invalid fault code".
Hi Filip, I replaced the ECU in March this year under the the post
OBD socket, no power.
By P38 Paul, March 8 . Surely it cant be that again could it?
