trod Posted February 3 Share Posted February 3 Hi,every one,are these new plugs any good? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted February 3 Share Posted February 3 This will be an 'upgrade' kit to replace the original '4 plugs connected in series' (each plug rated at 1.7 volts, with additional voltage being absorbed by a separate resistor), with four plugs connected in parallel (each plug rated at 11 volts). The upgrade being that with 4 plugs connected in series, if one plug fails they all stop working, meaning, in the UK the engine will not start from cold. With parallel connected plugs, if one fails the engine 'may' start on three plugs, dependant on the air temperature and general state of health of the engine. The difficulty in doing this is that the plug thread is different between the two styles of plug, which means the market for 12 volt plugs in a Series engine is very small. There are, or were, reputable plug makers who would supply this niche market, but Britpart being Britpart they seem to have gone to a no-name supplier. I do not have suppliers and pert numbers readily to hand. Regards. Quote Link to comment Share on other sites More sharing options...
steve b Posted February 3 Share Posted February 3 Turners list this as ERC8450 for late 5mb 2.25 and 2.5 diesel. The earlier 3mb 2.25 is 568335 Beru are a good brand. Steve Quote Link to comment Share on other sites More sharing options...
Cory Posted February 20 Share Posted February 20 I have used this kit. I would suggest to be careful tightening the wire nut on the end. It will break off if over tightened. It's not the greatest quality but they work. Later glow plugs do not fit the early series diesels. so we're kind of stuck with the BritPart version of parallel glow plugs. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 20 Share Posted February 20 The turners kit gets great reviews ! It gets used a lot on old Massey Ferguson’s, and they rate it. Quote Link to comment Share on other sites More sharing options...
tony109 Posted March 15 Share Posted March 15 (edited) On 2/3/2024 at 9:36 AM, trod said: Hi,every one,are these new plugs any good? They improved starting and worked perfectly on mine for years. The Britpart plug set is excellent. For the 2.25, upgraded Single heater plugs are shown as Part No. DA1057PLUG Edited March 15 by tony109 Quote Link to comment Share on other sites More sharing options...
