ltwt1981 Posted February 7, 2007 Share Posted February 7, 2007 Anyone help, my starter is a bit slow. Does any other motor fit a 2.25 petrol 3 bearing series 3. What about 2.5 petrol 90 or similar, and is it better/faster or more torque. Quote Link to comment Share on other sites More sharing options...
tiagoc Posted February 7, 2007 Share Posted February 7, 2007 i remember reading (here or on another forum? hmmm... ) that the starter from a 200tdi is a direct swap edit: only after i hit "submit", i read "petrol"... sorry for my previous useless info Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 7, 2007 Share Posted February 7, 2007 I think the old inertia starter motor on 2 1/4 engines was the most reliable product that Lucas ever produced. Just fit the same again, but first check that you have a good earth from the battery to the engine and or from the starter motor bottom bolt to the chassis. Also check that the lead from the solenoid or push button on early models to the terminal post on the starter motor is tight and secure. There were a number of 1950's British cars, trucks and tractors (Austins, Morrises, Vanguards , grey Fergussons) etc that used the same starter , but you are probably not likely to find any of those in breakers yards in the UK anymore. Bill Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 8, 2007 Share Posted February 8, 2007 Nige, You can fit the 2.5 petrol one but you need to swp the flywheel also as the ring gear is different. However they're no more reliable than the series ones, as at least there is no throw out on the solenoid of a series one. Jon Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted February 8, 2007 Author Share Posted February 8, 2007 Many thanks, I think I have a spare in the garage somewhere which I'll find and renovate on the bench I think. Just wondered if any of the later geared types would fit that was all. Quote Link to comment Share on other sites More sharing options...
s3landy Posted February 8, 2007 Share Posted February 8, 2007 Check out www.wiseowlparts.com and look at their rocky mountain starter.I have one and they are great. Mike Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 8, 2007 Share Posted February 8, 2007 Rocky Mountain starter is for diesel i think you will find. 2.5 petrol starter wont fit in this case as the flywheel wont swap, he has a 3 bearing engine not a 5 bearing. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 9, 2007 Share Posted February 9, 2007 Rocky Mountain starter is for diesel i think you will find.2.5 petrol starter wont fit in this case as the flywheel wont swap, he has a 3 bearing engine not a 5 bearing. I,ve never seen a 2.5 petrol over here. Are the ring gears not removable like the 2 1/4's? Bill. Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 9, 2007 Share Posted February 9, 2007 Bill, Yes they are removeable, but its alot less hassle just to swap the flywheel over! I've no idea if the ring gears are interchangeable or not - never tried! Swapping the flywheel is a nuts and bolts job. Jon Quote Link to comment Share on other sites More sharing options...
steve_a Posted February 10, 2007 Share Posted February 10, 2007 We used a 2.25 diesel starter with a 2.5 diesel if that is any help Nigel? As it happens I am about to remove a 200tdi starter (which is the same as the 2.5 one) so if you wanted to look at one I could possibly help. Quote Link to comment Share on other sites More sharing options...
s3landy Posted February 11, 2007 Share Posted February 11, 2007 I can't comment if the Rocky Moutain starter will fit a diesel but it does fit a 2.25 petrol. Mike Quote Link to comment Share on other sites More sharing options...
