simonpelly Posted August 12 Share Posted August 12 Hi Folks, In the process of changing the 'P' gasket on our 300Tdi Defender. Having a look at the water pump, it seems quite squeaky when turning by hand and not smooth. That said, there is no play. Attached is a video to hopefully help explain. I'd be interested in peeps thoughts on the condition. Many Thanks, Simon... P.S. Also having to deal with a broken bolt that holds on housing to the main engine block. Oh the joy! 300Tdi Water Pump.mp4 Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 12 Share Posted August 12 That’s completely knackered. Change it. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted August 12 Author Share Posted August 12 Thanks. I'll get one ordered. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 13 Share Posted August 13 Anyone know a good brand? They all seem to get squeaky very quickly, even if they’re serviceable. The tensioner pulley is often misdiagnosed as the source of squealing - it’s usually the water pump. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted August 13 Author Share Posted August 13 I've gone for the offering from Turner's - Proflow (OEM) Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted August 13 Share Posted August 13 (edited) As told, this is completely gone. It really wasn´t leaking? On a car with timing belt or v-belt driven pumps, the effort for changing belts normaly is so high, that the pump should be changed then anyway, when changing belts. On a 300 Tdi the pump is pretty cheap compared with this effort. Edited August 13 by Sigi_H Quote Link to comment Share on other sites More sharing options...
simonpelly Posted August 13 Author Share Posted August 13 There was some leaking hence the strip down. Not sure whether the leaking was due to a failed P gasket or the pump. Both are (were) original (1997, 90 odd thousand mile). In any case, both will be replaced. The coolant of choice has been TRIPLE QX Blue Ready Mixed Antifreeze/Coolant 5Ltr - which is an ethylene glycol based anti-freeze as recommended - and been replaced religiously every two years. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted August 13 Share Posted August 13 Mine original fit one failed suddenly with no notice. My coolant level alarm kicked-in. It was leaking at the tell-tale hole underneath it. I replaced with a Pro Flow one and as it wasn't expensive I bought a spare. So far so good but I've probably done less than 1,000 miles since fitting. This is what the seal looked like and it felt horrible when turning it. Quote Link to comment Share on other sites More sharing options...
fmmv Posted August 13 Share Posted August 13 I coat the bolts with Duralac, and put copper grease on the threads. So far undoing has been easy, now on third pump, but I also keep a spare 3 Quote Link to comment Share on other sites More sharing options...
