SatNav for Seven Sisters
Mark
I prepaation for the Shires Seven Sisters weekend, I have been thining about My Sat Nave...
Currently Running Memory Map on my iPaq which works very well... where the roads are mapped. Miketomcat showed me what I think was oziexplorer using a combination of scanned OS map and aerial photos but can I do that with MM? I think possibly not.
Can I run Ozi on a iPaq? if so does anyone have the scanned maps/photos that I need to sue with it?
Any help appreciated... :)
ta
Mark
Memory-Map have full UK OS mapping available at various scales as well as aerial photography maps too.
Yes you can, there is a PocketPC version. You'd have to scan and calibrate the maps yourself though.
Meant to say that I am using MM2004 - since I have the entire UK on 1:50k but am too cheap to upgrade... does that version accept aerial photographs?
Will have to investigate Ozi a bit deeper though...
If you buy a new map set then they will come with the later application anyway?
I have a high res aerial photo of the site if anyone wants a copy. Its A3 at 200 dpi I think, 25cm resolution
Not had much at calibrating it for MM though, did it off six points and it was still about 250m out!
Yes please :D
I've not tried calibration in MM, but its easy enough in Ozi-explorer.
If I can get it calibrated, I can make the calibration available too.
andrew AT marshallsay dot com
