pugwash Posted April 22, 2007 Share Posted April 22, 2007 I'm trying to remove the hydraulic motor from my milemarker winch, but it seems to need a 9mm hex key which seem to be extremely rare. as it's a yank piece of kit, is their an imperial measure which is slap bang between 8mm and 10mm? Quote Link to comment Share on other sites More sharing options...
madmatt Posted April 22, 2007 Share Posted April 22, 2007 I'm trying to remove the hydraulic motor from my milemarker winch, but it seems to need a 9mm hex key which seem to be extremely rare. as it's a yank piece of kit, is their an imperial measure which is slap bang between 8mm and 10mm? If I remember rightly you want a 3/8" allen key for the milemarker. Matt Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted April 22, 2007 Share Posted April 22, 2007 Jim, Yes, 9mm Allen wrenches are readily available ……………… IIRC that is also the size of the LT77 fill plug. It’s a fair bet that the MM bolts are imperial heads as I know definitely that the threads are imperial…………… 9mm equates to 11/32 , but the most realistic size is probably 3/8 which is a shade under 9.5mm. Ian Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2007 Share Posted April 22, 2007 This should help Zues tables from the Tech Archive, it'll tell you everything Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 22, 2007 Share Posted April 22, 2007 Jim , I have a 9mm 3/8drive hex socket if you need one , But if its Yanky sizes its more likely to be 5/16" or 3/8" wich I also have , If you need them let me know . Im down at Culmhead on Sat and sun . Quote Link to comment Share on other sites More sharing options...
rob90 Posted April 22, 2007 Share Posted April 22, 2007 If I remember rightly you want a 3/8" allen key for the milemarker.Matt I have also come across this odderty in my old plant fitting days 3/8", or depending on how rough you want to be lashings of wd40 leave to soak in then hammer flat headed screwdriver in and then replace with something more run of the mill Quote Link to comment Share on other sites More sharing options...
pugwash Posted April 22, 2007 Author Share Posted April 22, 2007 cheers all, i'll go out and buy some imperial keys, jase if i don't have them by the weekend then i'll pop up and borrow yours if thats ok! Quote Link to comment Share on other sites More sharing options...
madmatt Posted April 23, 2007 Share Posted April 23, 2007 I have also come across this odderty in my old plant fitting days 3/8", or depending on how rough you want to be lashings of wd40 leave to soak in then hammer flat headed screwdriver in and then replace with something more run of the mill Suppose that would work, having served an apprentaship in agricultural enginering I just had to bite the bullet and by kit in metric and imperial though! Quote Link to comment Share on other sites More sharing options...
kiall Posted April 23, 2007 Share Posted April 23, 2007 Suppose that would work, having served an apprentaship in agricultural enginering I just had to bite the bullet and by kit in metric and imperial though! am actually serving my time as a agricultural engineer and i need both going upto very large sizes Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 23, 2007 Share Posted April 23, 2007 cheers all, i'll go out and buy some imperial keys, jase if i don't have them by the weekend then i'll pop up and borrow yours if thats ok! I will be there from Fri night, Just listen out for the Wurzels blasting out and then youll find us . Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 23, 2007 Share Posted April 23, 2007 The Wurzels are playing in Trowbridge soon. Might have to pop along and see them :D Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 23, 2007 Share Posted April 23, 2007 well worth a look , They are playing in my local on the 6th May . Quote Link to comment Share on other sites More sharing options...
