Phil Posted May 10, 2007 Share Posted May 10, 2007 In addition to bits of paint falling off, I need to deal with a leak which is flooding the driver's footwell. The water's dripping off the bottom of the metal strip that holds the windsreen frame and bulkhead together (the black strip in the photo). The seal appears dry and I can't see any clear sign of where the actual leak is. What's the best way to tackle this? Phil. Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted May 10, 2007 Share Posted May 10, 2007 Get large drill and make two holes in foot well towards the drivers seat to allow the water to drain out, then praise Land Rover for the unique boot washing system. Quote Link to comment Share on other sites More sharing options...
Phil Posted May 10, 2007 Author Share Posted May 10, 2007 Get large drill and make two holes in foot well towards the drivers seat to allow the water to drain out, then praise Land Rover for the unique boot washing system. Love to, but the water's making my bulkhead rusty so I think I'd better try to keep it out!! Phil. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted May 10, 2007 Share Posted May 10, 2007 Pull the door seal off in the area of the windscreen to bulkhead join and shove some sealant in there. You might want to undo the joining strip bolts and splodge some sealant in around the bolt threads and run a bead of sealant along the filler strip before refitting the bolts. Also check that the sealant in the gutter of the hardtop and along the top of the windscreen frame / hardtop too. Take a look at the same join under the doorseal too. Quote Link to comment Share on other sites More sharing options...
Phil Posted May 10, 2007 Author Share Posted May 10, 2007 Pull the door seal off in the area of the windscreen to bulkhead join and shove some sealant in there. You might want to undo the joining strip bolts and splodge some sealant in around the bolt threads and run a bead of sealant along the filler strip before refitting the bolts. Also check that the sealant in the gutter of the hardtop and along the top of the windscreen frame / hardtop too. Take a look at the same join under the doorseal too. Steve, thanks, I take it I can remove the joining strip to work on the area without anything untoward happening? Many thanks, Phil. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted May 11, 2007 Share Posted May 11, 2007 I've never had problems Phil, undo one bolt at a time if you are worried. Quote Link to comment Share on other sites More sharing options...
Phil Posted May 11, 2007 Author Share Posted May 11, 2007 I've never had problems Phil, undo one bolt at a time if you are worried. Thanks, Steve, I'll give it a go later if the rain stops! Cheers, Phil. Quote Link to comment Share on other sites More sharing options...
derodster Posted May 11, 2007 Share Posted May 11, 2007 sound advice there. I had this problem too and the seal was the problem. Water works its way around the crease near the join and then across the top of footwell or door stop bracket. Sealant did the job Rod 1985 LR90 Quote Link to comment Share on other sites More sharing options...
doddel Posted May 11, 2007 Share Posted May 11, 2007 and what sealant do you recommend? Quote Link to comment Share on other sites More sharing options...
Phil Posted May 11, 2007 Author Share Posted May 11, 2007 and what sealant do you recommend? Right, as it was dry this afternoon, I've been busy. I did everything Steve suggested and fitted a new door seal too. I used a Loctite silicon sealant which a friend recommended. All I need now is a good downpour and a dry footwell afterwards!!! When I have more time. I need to clean the rust off the door stop bracket and the seam along the top of the footwell. Cheers! Phil. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 11, 2007 Share Posted May 11, 2007 I did similar today with my black pool sealant and then it rained hard.... All nice and dry in there still..... Yipeeeeeeeeee...... (Only problem now is the dirty boots won't get cleaned !) Quote Link to comment Share on other sites More sharing options...
Phil Posted May 11, 2007 Author Share Posted May 11, 2007 I did similar today with my black pool sealant and then it rained hard....All nice and dry in there still..... Yipeeeeeeeeee...... (Only problem now is the dirty boots won't get cleaned !) Hope I've had similar success, still no rain here so I might still be getting my boots cleaned!!! Phil. Quote Link to comment Share on other sites More sharing options...
white90 Posted May 12, 2007 Share Posted May 12, 2007 grease/or peroleum jelly on the o/s of the seal stops water going through it to Quote Link to comment Share on other sites More sharing options...
Phil Posted May 12, 2007 Author Share Posted May 12, 2007 grease/or peroleum jelly on the o/s of the seal stops water going through it to Well, I hope this isn't premature, it rained overnight and the footwell's dry this morning so that looks like good news! Thanks, Steve! Phil. Quote Link to comment Share on other sites More sharing options...
gazelle Posted June 24, 2007 Share Posted June 24, 2007 grease/or peroleum jelly on the o/s of the seal stops water going through it to I have now sealed my vents with Vasoline as a result of this advice - works a treat. Cheap too! Thanks Quote Link to comment Share on other sites More sharing options...
