bobonacus Posted June 28, 2007 Posted June 28, 2007 I've got an '86 90 with a 200 Tdi fitted in. The air intake pipe into the airbox just sits in the engine bay. Should it mount up to the inside of the n/s wing? I have bought a snorkel which bolts to the outside of the n/s wing but I assume there should be something in the engine bay already for it to bolt to cheers Robert Quote
Ex Member Posted June 28, 2007 Posted June 28, 2007 There is a hose from the airbox to the left hand side wing vent. Quote
bobonacus Posted June 28, 2007 Author Posted June 28, 2007 I've got the hose but it just kinda sits there, it doesn't join to anything on the wing, is there a piced of plastic that it clamps to on the wing? Quote
LandyManLuke Posted June 28, 2007 Posted June 28, 2007 Yup, the 200tdi has a bit of plastic that sits between the hose and the hole in the wing. Quote
Lars L Posted June 28, 2007 Posted June 28, 2007 And since your 90 is of 1986 vintage, there is no side wing vent. That came with the 200Tdi around 1990. As yours clearly has been converted, what aircleaner do you have? If it's the old one from a petrol/2,5 NAD, it's of course possible to route a hose from that to the snorkel. But - you have to make the hole in the wing yourself and possibly also get the bits that your snorkel is supposed to attach to. I made my own snorkel from 2,5" pipe but made a hole on top of the wing just ahead of the bulkhead. Attached by a flexible hose going to the Disco airbox which sits on the LH side. Quote
western Posted June 28, 2007 Posted June 28, 2007 This is the parts fitted to the 2.5TD & 200Tdi engined 90/110's to the left side front wing panel, the pipe section fits from inside & grille from outside, the panel has a recess pressed into it when made so the grille sits almost flush, hope it helps Quote
bobonacus Posted June 28, 2007 Author Posted June 28, 2007 cool, thanks for that I have the vent just not the bit behind, I'll have to find someone breaking one! Quote
landrover598 Posted June 28, 2007 Posted June 28, 2007 I'm sure i've got those two bits in the shed, i'll look in the morning. Quote
bobonacus Posted June 28, 2007 Author Posted June 28, 2007 I'm sure i've got those two bits in the shed, i'll look in the morning. Ohh, if you have that'd be fab. If you have let me know how much you want for them cheers Robert Quote
bobonacus Posted June 29, 2007 Author Posted June 29, 2007 I've ordered all the bits apart from no.4 on that diagram, the lower pipe MWC1827 from David Vincent for £14 If anyone has the lower part that'd be really helpful as Land Rover don't seem to do that bit anymore! I guess the flexi pipe may be able to be attached to the main part (no.3) anyway so may be ok Quote
JST Posted June 29, 2007 Posted June 29, 2007 when you fit your snorkel dont forget to do something with the dump valve, see the thread from HH snorkel fitting in INt Forum. Quote
landrover598 Posted June 30, 2007 Posted June 30, 2007 I've found the two plastic bit (No. 3&4 in the pic) Do you still want them ? where abouts are you ? Quote
bobonacus Posted June 30, 2007 Author Posted June 30, 2007 I've found the two plastic bit (No. 3&4 in the pic)Do you still want them ? where abouts are you ? yes please. i just need part 4. i am ib bracknell, berks Quote
