forkrentfitter Posted December 25, 2007 Share Posted December 25, 2007 hi,i,me new to the forum,i have just acquired a rr classic,with standard suspension,i want to off road it this weekend,i have a set of 7.50x16 goodyear g90 on discovery steel rims,will i get away with just trimming the wings,the rr will only be used offroad. Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted December 26, 2007 Share Posted December 26, 2007 yes, you should get away with just trimming the wings, but wheel spacers is advised aswell. dont take my word for it, im still a noob Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 26, 2007 Share Posted December 26, 2007 No trimming required at the front. At the rear you will need to trim or fold flat the return on the front edge of the arch unless you want it to trim the nobbles off your tyres! You may also need to trim the trailing edge too. To avoid the annoying rubbing on the radius arms you will need to adjust your lock stops too. If you are going to off road it immediately then please make sure you have sound recovery points front and rear bedfore you go. Enjoy Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 26, 2007 Share Posted December 26, 2007 *IF* you use it on road, watch the speed rating Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted December 26, 2007 Share Posted December 26, 2007 Yes indeed good point. G90 appear to be N rating which is 87 mph so too slow for a Discovery/RR. THink you'd need minimum of Q rating. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 26, 2007 Share Posted December 26, 2007 I ran 7.90x16 Rangemasters on my range rover, without any trimming at all. They did rub very slightly on the radius arms so could have done with the steering stops adjusted (I didn't as I ran standard tyres for road use). No problems at all at the back. Not sure if you'll have more issues with the more agressive G90s - in theory they should be exactly the same size, but tyre sizes can be somewhat variable! Quote Link to comment Share on other sites More sharing options...
clbarclay Posted December 27, 2007 Share Posted December 27, 2007 I had 7.50 SATS on 33mm (standard) offset wheels had no problems apart from the steering stops. I then had some SATs on modulars with 11mm of set and it can just catch the front arches at extremes and catches the rear arch slightly next to the rear doors. That was with stiffer springs though standard bump stops and before a body lift. Quote Link to comment Share on other sites More sharing options...
