lard a**e Posted January 2, 2008 Share Posted January 2, 2008 i am having some bother with the instroments in my 1989 3.5 efi rangey, the lights on the auto and heater controlls work fine, auto lights seam to be on all the time, all instroment lights work (apart from fuel low warning as bulb removed when fiting new tank in trayback build), but the dash lights have gone off so cant see temp gauge, revs on for all id dosent matter to much(small auto cooler meens ceep it below 2500rpm on the road) the speedo when it gets dark, anyone have any ideas Quote Link to comment Share on other sites More sharing options...
jules Posted January 3, 2008 Share Posted January 3, 2008 Run a wire up from the lights that do work to the one that don't (Im not helping much am I) Sorry I'll get my coat. Never take wiring advice from one of the Read brothers Quote Link to comment Share on other sites More sharing options...
paintman Posted January 3, 2008 Share Posted January 3, 2008 Dimmer switch needs adjusting? If the heater and other switch lights work correctly with the dimmer I suggest you check the bulbs and connections in the binnacle. Not sure where the dimmer switch is on the 89 but on my 86 it is on the underside of the dash ('lower fascia panel')above your left knee & looks like a wheel. Guess it would be in the same place. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted January 4, 2008 Share Posted January 4, 2008 Dimmer switch needs adjusting?If the heater and other switch lights work correctly with the dimmer I suggest you check the bulbs and connections in the binnacle. Not sure where the dimmer switch is on the 89 but on my 86 it is on the underside of the dash ('lower fascia panel')above your left knee & looks like a wheel. Guess it would be in the same place. It is in the same place. Might just have got disconnected - have you been doing any work round there recently, and did you remember to plug it back in afterwards? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 4, 2008 Share Posted January 4, 2008 Shouldn't be hard to trace, just fiddly to get to - there'll be a feed from the sidelight switch position to the bulbs, and a ground. One or the other will go via the dimmer. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 29, 2008 Share Posted January 29, 2008 any luck? Quote Link to comment Share on other sites More sharing options...
SteveRK Posted January 29, 2008 Share Posted January 29, 2008 On mine the dimmer switch also controls the heater lights so if they are working then its unlikely to be the cause. Quote Link to comment Share on other sites More sharing options...
