who had built a 100" defender
simon red90
so i've picked up a 300tdi disco really cheap and have always wanted a 100" defender.
i figure i need to put a new rear cross member on it, outriggers, obviously the bodywork, tub and tank mounts, but what else? will i need to get a defender R380 box or keep the disco item?
if anyones built one, just an outline would be much appreciated.
cheers. si
cheers. si
Save yourself the work and drive the disco! :D
i would never swap my disco for a defender, i like my comfort to much!
i assume the 300 tdi Disco is rotten as a pear hence the question?
having said that, you are basically building a hybrid, equally take a shufty at my build thread in the members vehicle section..... Another 100" Shires Kingcab, it was on about page 3 the last time i looked. Admittedly its a RRC 3.9 Auto, but the basic idea's the same.
cheers. si
If you want a 100" chassis thats been de bracketed and 90 out riggers fitted i've got one here!
My 3 pences worth is that 100" allows you to move the engine/box back,the truck cab back and still tray the rear.
This allow room for a 3/4 link at the front,the engine is more central and the cab,outriggers ,moved back a little to allow for 40"tyres.
theres alot of work after you've finished the chassis and you'll need a 90/110 for the rest of the bits.
I'd personally go cut down 110 hi cap etc,you've got all the parts and a v5,just needs amending B)
ok, cheers folks, i'm not building a challenge truck, although i see huge merit in using a 100" chassis for one. i wanna build a defender for towing but without the size of a 110. and since i've landed a (top half worn out) 300 disco at the right price, i'm gonna give it a shot. i'll let you know how i get on.
si
