gbmoto Posted January 18, 2008 Share Posted January 18, 2008 Hi All Anyone know if my three spokes can be used tubeless?? I have checked the number on the side and they do not seem to correspond to any rover part number. From the parts list I have the three spoke has been listed as tubed and tubeless. currently it looks like they have tubes in, I would rather run my new tyres tubeless. Any ideas?? Quote Link to comment Share on other sites More sharing options...
V8david Posted January 18, 2008 Share Posted January 18, 2008 Three spoke RR alloys are tubeless aren't they? Mine are. What year is your vehicle? I assume as you say according to the parts list you can do either. Your local tyre fitting specialist should be able to tell you. Also doesn't it say on your tyres if they're tubeless or not? Mine do. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 18, 2008 Share Posted January 18, 2008 There are tube and tubeless versions, the part numbers are different and the word "TUBELESS" or "TUBE TYPE" should be cast into the rim like the writing in your photo. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 18, 2008 Share Posted January 18, 2008 Yep, mine have 'TUBELESS' cast into the rim, as FF says Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 18, 2008 Share Posted January 18, 2008 Looks like yours are tube type Chris Quote Link to comment Share on other sites More sharing options...
gbmoto Posted January 19, 2008 Author Share Posted January 19, 2008 Many thanks to the replys chaps. The wheels are on a Defender so i have no idea of age, currently it looks like the tyres have tubes, although they are tubeless tyres. Where does it say on the rim whether tubed or not? Mine say nothing on the outer rim. Thanks again Quote Link to comment Share on other sites More sharing options...
paintman Posted January 19, 2008 Share Posted January 19, 2008 Just had a look at my RRC & the word TUBELESS is between the rim size & the number NTC2688. You have the rim size & the number NRC7900 with nothing between the two. Quote Link to comment Share on other sites More sharing options...
gbmoto Posted January 19, 2008 Author Share Posted January 19, 2008 Thanks Paintman, I recon mine are definitely tubed then. Many thanks all. Quote Link to comment Share on other sites More sharing options...
