The Badger Posted February 14, 2008 Share Posted February 14, 2008 In comparison to all the other thing I have done so far, this sound's like it should be simple - right. Anyhow, could someone please tell me how I should wire up my map light? It's an Avanti map light from here : http://www.vehicle-wiring-products.eu/VWP-...ng/interior.php anyone? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 14, 2008 Share Posted February 14, 2008 Black goes to ground, red goes to a fused +12v feed, either ignition live (white) or permanent live (brown). The light won't draw much current so a 3A fuse will be fine, 0.5mmsq wire will suffice for wiring, and you can pick up the power from any spare point you can find. You can use piggy-back connectors to pick up from an existing point, or run a wire right back to the battery terminal. If you do, put the fuse as near the battery as possible, using a waterproof inline fuse holder: Just don't use scotchloks. Quote Link to comment Share on other sites More sharing options...
western Posted February 14, 2008 Share Posted February 14, 2008 same as mine, I just connected into the purple permanent live & a earth behind the clock/cig lighter in the lower dash centre panel. the map light sits over the passenger side just below the lip of the dash tray. Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 14, 2008 Author Share Posted February 14, 2008 Thanks this is perfect. Quote Link to comment Share on other sites More sharing options...
Scotian Posted February 15, 2008 Share Posted February 15, 2008 Watch out for this light. I never liked them in The Wolfs becuase its not hard to leave it on by accident or accidently switch it on in day light. If its left on for more than a few hours the bulb gets hot enough to melt the plastic shade. So best thing would be (as already advised) to wire it to an ignition live wire. Quote Link to comment Share on other sites More sharing options...
Gromit Posted February 15, 2008 Share Posted February 15, 2008 I just bought one of these: It's an aircraft map light, and amazingly well built. It's removable from the base, which I've fixed to the dash, so you can pull the light for rummaging in the cubby box or behind the front seats. Also has a red filter for that Hunt For Red October look Quote Link to comment Share on other sites More sharing options...
Mark Posted February 15, 2008 Share Posted February 15, 2008 That's a lot like mine... Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 15, 2008 Share Posted February 15, 2008 why not link the supply feed to the sidelight circuit? surely you don't need it on ignition live, after all, who needs a map light during daylight hours? Quote Link to comment Share on other sites More sharing options...
Scotian Posted February 15, 2008 Share Posted February 15, 2008 why not link the supply feed to the sidelight circuit? surely you don't need it on ignition live, after all, who needs a map light during daylight hours? When you are parked up with the lights on trying to use at little power as possible while you plan tomorrows trip F*#% it. use a head torch Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 15, 2008 Share Posted February 15, 2008 Stick an LED bulb in the end and you're sorted - could probably leave it on permanently! Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted February 15, 2008 Share Posted February 15, 2008 or use a wind up torch and reduce your carbon foot-print. Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 15, 2008 Share Posted February 15, 2008 or use a wind up torch and reduce your carbon foot-print. would that help balance out the V8's footprint? Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 15, 2008 Author Share Posted February 15, 2008 Glow worms work well too I hear. Carbon footprint is a bit of a hard issue to tackle when you already drive a landy... Well not unless it's LPG or veg oil. Speaking of veg oil, who knows why on the new 07 90, it's says do not use Bio Diesel? you think this is something you could fix, i.e it's the seals / fuel filter elements like that. Quote Link to comment Share on other sites More sharing options...
