wkw90 Posted February 22, 2008 Share Posted February 22, 2008 Picked up an engine to replace mine (3.5 V8 ) came with SU's fitted my old lump has the strombergs fitted . So what should i use Quote Link to comment Share on other sites More sharing options...
k9unit Posted February 22, 2008 Share Posted February 22, 2008 stroms every time better carb paul Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 22, 2008 Share Posted February 22, 2008 Don't know about Stombergs but SU HIF you can adjust the mixture with a screw not factory set only? This proved very usefull to me on both my V8 Land Rovers but might not be important to you as I had changed my exhuast systems from standard. Marc. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 22, 2008 Share Posted February 22, 2008 I was always under the impression SUs were better...can't give any reasons other than someone told me... Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 22, 2008 Author Share Posted February 22, 2008 Don't know about Stombergs but SU HIF you can adjust the mixture with a screw not factory set only?This proved very usefull to me on both my V8 Land Rovers but might not be important to you as I had changed my exhuast systems from standard. Marc. Planing on an exhuast systems change so that may be of help . Quote Link to comment Share on other sites More sharing options...
Guest weeble Posted February 22, 2008 Share Posted February 22, 2008 Personally I would use the SU`s anytime but only if youve got all the other bits to go with them. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 22, 2008 Author Share Posted February 22, 2008 SU's it is then , thanks Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 23, 2008 Share Posted February 23, 2008 SU are far superior off road, and many RR 3.5 switched to SU for improved performance and tuning capabilities Nige Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 23, 2008 Share Posted February 23, 2008 I'd go for strombergs every time but I couldn't get the manifolds for my 300 Tdi Coat ........ and running Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 23, 2008 Author Share Posted February 23, 2008 SU are far superior off road, and many RR 3.5 switched to SU for improved performance and tuning capabilitiesNige Thanks Dad Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 23, 2008 Author Share Posted February 23, 2008 I'd go for strombergs every time but I couldn't get the manifolds for my 300 Tdi Coat ........ and running Mo Got a V8 spare for you Mo Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 23, 2008 Share Posted February 23, 2008 No Paul, you have the knackered parts of a spare v8 for me Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 23, 2008 Author Share Posted February 23, 2008 No Paul, you have the knackered parts of a spare v8 for me Mo Still better than a TDI Quote Link to comment Share on other sites More sharing options...
tacr2man Posted February 23, 2008 Share Posted February 23, 2008 both SU and stromberg are adjustable but the strom needs a special tool. THe HIf SU tunes a bit better because the jet assy compensates for fuel temp THe other plus for the SU is no rubber diaphagm to split thats about it both are constant depression variable orifice and jet carbs you pays your money and takes your choice Quote Link to comment Share on other sites More sharing options...
