Weld On Beadlocks
Ian M
ive been looking at these, and ive got a couple of queries!
1: how do they stop the inner bead from popping off the rim?
2: has anyone made their own? are the rings the exact same diameter as the rim? and what metal and thickness did you use?
3: any one got any pics showing how they are welded one?
Gary Andrews is the man to speak too , IIRC he makes a set of 5 for about £100 , Thats for the rings and not the wheels .
i spoke to him yesterday, £110 for 16 inch, but he cant deliver for a few weeks at least! so thats why i was looking into making my own!
Another vote for Gary here ,
Got mine a couple of weeks ago, I don't think you would get them any cheaper as a one off order with your local laser cutting metal shop....6mm steel inner rings and 6mm stainless outer rings, 16 bolt m10 holes. they are a good fit inside the outer lip :ph34r: of the wheel so I chamfered the outer edge to give a nice weld fillet when dressed flat.....Oh and i went for some nice Stainless button socket head bolts for a nice finish. Welded mine with a 185amp welder with the wire feed down a little and the trans. on max for good penetration.
......double beadlocks are another level, I'd say Stauns would be the simplest way of achieving that ;)
Cheers
Steveb
