pugwash Posted April 3, 2008 Share Posted April 3, 2008 Is there any reason why an exhaust can't exit under the middle of a vehicle? does it have to exit to free air for any reason? Are there any legalilities to be aware of when routing exhausts pipes and exits? Quote Link to comment Share on other sites More sharing options...
Night Train Posted April 3, 2008 Share Posted April 3, 2008 Looking at lorry exhausts they seem to exit underneath the load area or the off side or, in the case of tankers, at the front. I guess it probably needs to not allow fumes into the driver/passenger area or be at face level to pedestrians. Quote Link to comment Share on other sites More sharing options...
sgnas Posted April 3, 2008 Share Posted April 3, 2008 The last two 7.5tonners (horseboxes) we've had exit under the middle. On a passenger vehicle it could be different to stop fumes in the cabin! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 3, 2008 Share Posted April 3, 2008 Yep, it must not terminate under the passenger compartment - I think it is an MOT requirement. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2008 Share Posted April 3, 2008 Bish is right - it must be in line with or slightly proud of the vehicle so that exhaust fumes can't enter the driver/passenger compartment. You can have the exit anywhere you like as long as it follows those rules. Les. Quote Link to comment Share on other sites More sharing options...
p38arover Posted April 3, 2008 Share Posted April 3, 2008 Bish is right - it must be in line with or slightly proud of the vehicle so that exhaust fumes can't enter the driver/passenger compartment. You can have the exit anywhere you like as long as it follows those rules.Les. In Australia, the exhaust must exit behind the last opening window if I recall correctly. Dunno what they say about lifting tailgates. Ron Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 3, 2008 Share Posted April 3, 2008 not to pee on fireworks but what about cobra/westfield kit cars they both exit buy drivers/passinger door area and iirc they pass SVA and MOT's mike Quote Link to comment Share on other sites More sharing options...
Night Train Posted April 3, 2008 Share Posted April 3, 2008 But aren't they just behind the seating though. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 3, 2008 Share Posted April 3, 2008 My 100" exits before the rear X member but points downwards and was SVA'd like that. Both Auverland A£'s and G Wagens have exhausts that exit before the start of the rear wheel arch Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted April 3, 2008 Share Posted April 3, 2008 is there a hight limit? i heard that you cant have a side exit above a certain hight as it will blow fumes into lower cars open windows? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 3, 2008 Share Posted April 3, 2008 The point is that all these exhausts exit. They don't stop under the floor so when you are stuck i traffic the exhaust gasses are trapped under the vehicle and may find their way into the passenger compartment. Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted April 3, 2008 Share Posted April 3, 2008 my minibuses all exit out the offside in the middle, Quote Link to comment Share on other sites More sharing options...
