MINESAPINT Posted April 10, 2008 Share Posted April 10, 2008 I am about to purchase either a new 2008 Puma but do have the opportunity to buy a 1 year old model with 4,000 miles on the clock. Obviously I will save a few quid by going for the second hand model but I am wondering if there have been any significant changes in the spec from 07 to 08? Thanks MINESAPINT Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 10, 2008 Share Posted April 10, 2008 Nothing particularly exciting that I am aware of. Quote Link to comment Share on other sites More sharing options...
JST Posted April 10, 2008 Share Posted April 10, 2008 Nothing i have heard of yet Coudl check to see if it comes with the revised sump pan i guess? Quote Link to comment Share on other sites More sharing options...
MINESAPINT Posted April 10, 2008 Author Share Posted April 10, 2008 I have read bits & pieces ref the sump pan but can't say I fully understand the problem/solution? Perhaps someone will explain. I imagine if the 1 year old model has not had the modification I will be able to request it on the outstanding warranty? Thanks MINESAPINT Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 10, 2008 Share Posted April 10, 2008 It's not a warrenty job. Only on showing damage to sump/prop will the work be carried out, OFFICIALY Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 10, 2008 Share Posted April 10, 2008 It's not a warrenty job. Only on showing damage to sump/prop will the work be carried out, OFFICIALY Re sumps, to keep the site tidy !!! see Puma Sump Thread Quote Link to comment Share on other sites More sharing options...
alantd Posted April 11, 2008 Share Posted April 11, 2008 Summary: At full articulation, there have been reports that the oil pan comes into contact with the axle. Symptoms are banging when off road (full suspension travel) and witness marks on the pan. Solution is a slightly modified pan (with a chunk taken out). Land Rover claim that it is only a problem on Left Hand Drive vehicles and, as a result, won't recall vehicles but instead only address the issue if a customer complains of noise and can show witness marks. A couple of people here have had them replaced by the dealer already, which implies that either the problem does occurr on RHD cars or dealers will do it if asked, regardless. I understood that from November 07, the new pan was fitted as standard (although presumably once the'd used up the stock of old ones). Beyond that, I don't think there have been any changes to the 08 model. All the changes were reserved for the SVX. Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 11, 2008 Share Posted April 11, 2008 If you plan to buy one that is 6-12 months old do your research and shop around as some dealers take the 'P' and you don't save that much over buying new and getting a discount. I took my time and ending up buying a 6 month old 90 with 3K miles on and it was about £6,000 less than new. Same with 110 XS, worked out about £6,500 less for 6 months old and 8K miles. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Mack Posted April 11, 2008 Share Posted April 11, 2008 It's not a warrenty job. Only on showing damage to sump/prop will the work be carried out, OFFICIALY Can´t belive it . I guess I have then to do the marks on my own! rather that than being in the middle of Bolivia with a holed sump! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 11, 2008 Share Posted April 11, 2008 Mine is going in for some warranty work later this month. I asked about the sump issue and they (The Dealership) denied all knowledge of the tech bulliten. When I pushed them they had to call LR direct to ask them. They called me back and said that my veh doesn't have any recalls for my chassis range. When it goes in I'll take a copy of the tech bulliten and push them a bit harder and see what that does. Quote Link to comment Share on other sites More sharing options...
q-rover Posted April 11, 2008 Share Posted April 11, 2008 When it goes in I'll take a copy of the tech bulliten and push them a bit harder and see what that does. In the mean time have a look at the sump, they might be right. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 11, 2008 Share Posted April 11, 2008 Think the last few posts re sumps, belong on the Sump thread !!! Mine's done, for the cost of a oil filter !! and that's only cause i ask them to change while there !! Quote Link to comment Share on other sites More sharing options...
