J@mes Posted May 22, 2008 Share Posted May 22, 2008 My bottle jack failed today while I was lifting my disco (luckily the wheel was still on so nothing was damaged) and from the looks of it, the casing has cracked slightly! So, does anyone know where to get a replacement bottle jack that has the correct shaped head? I looked on ebay, machine mart and various other places and could only find ones with flat heads - which doesnt really appeal to me from a safety point of view! I have found a couple of mercedes sprinter tool kits on ebay, and the bottle jacks in them have the correct head, but I am curious to see if there are any more about - LR wanted £93 for a new one! thanks James Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 22, 2008 Share Posted May 22, 2008 Could you buy a normal one and weld a shoe on the top? I paid £20 for a 20T bottle jack (a little safety margin there then ) and just welded a bit of ~1/2" plate to the top to give a nice big flat jacking area. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 22, 2008 Share Posted May 22, 2008 The head is less of an issue than the fact that most cheap bottle jacks have not got the lift range to elevate a completely flat 7.50x16 tyre up to a height that you can fit an inflated one on - most are only single stage with a screw out second stage whereas what you need is a proper two stage one. The single stage ones are fine for changing one wheel for another but try doing it with the tyre flat... Quote Link to comment Share on other sites More sharing options...
clbarclay Posted May 22, 2008 Share Posted May 22, 2008 Hi lift? There are some second hand disco bottle jacks on the bay http://cgi.ebay.co.uk/LANDROVER-DISCOVERY-...1QQcmdZViewItem http://cgi.ebay.co.uk/LAND-ROVER-DISCOVERY...VQQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 22, 2008 Share Posted May 22, 2008 Hi lift? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 22, 2008 Share Posted May 22, 2008 Go to a scrappy, a friend of mine picked up two Range Rover bottle jack setups (jack, two handles, 2 wheel chocks) for £15 the pair. I have 2 myself, (from my Rangies ) and find them invaluble, nothing like having a pair of jacks with exactly the same characteristics when getting a vehicle up on stands/blocks.... so much easier. Quote Link to comment Share on other sites More sharing options...
dreadnought110 Posted May 22, 2008 Share Posted May 22, 2008 I used to have a mercedes truck one till i realised it wouldn't fit under the axle when i had a flat tyre!!! and it wouldn't lift high enough to let the axle hang!! Quote Link to comment Share on other sites More sharing options...
Escape Posted May 23, 2008 Share Posted May 23, 2008 The head is less of an issue than the fact that most cheap bottle jacks have not got the lift range to elevate a completely flat 7.50x16 tyre up to a height that you can fit an inflated one on - most are only single stage with a screw out second stage whereas what you need is a proper two stage one. The single stage ones are fine for changing one wheel for another but try doing it with the tyre flat... One way to overcome this, is to drive the flay tyre up on a (thick) piece of wood or similar, then jack up the axle, remove the flat tyre and wood and you should have enough room to refit an inflated tyre. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 23, 2008 Share Posted May 23, 2008 One way to overcome this, is to drive the flay tyre up on a (thick) piece of wood or similar, then jack up the axle, remove the flat tyre and wood and you should have enough room to refit an inflated tyre. Yes a small bit of 3x9 or something will work but it is more faff than having a bottle jack the right size Quote Link to comment Share on other sites More sharing options...
J@mes Posted May 23, 2008 Author Share Posted May 23, 2008 Thanks for the replies - I have a friend on the hunt for one as he thinks he may have some tucked away. will know after the weekend. other than that, it looks like ebay (risk of buying another dodgy one) or buying a new one and getting someone to weld a head on the top. I am still confused as to why none of the manufacturers offer one with an axle tube head on! Quote Link to comment Share on other sites More sharing options...
Escape Posted May 23, 2008 Share Posted May 23, 2008 Yes a small bit of 3x9 or something will work but it is more faff than having a bottle jack the right size Don't get me wrong, I'm a big fan of the 2-stage LR jack, but if need be, it's nice to have some options even with a lesser speced jack. Quote Link to comment Share on other sites More sharing options...
tychoS Posted May 23, 2008 Share Posted May 23, 2008 Rimmerbros had what from the picture looked like the original LR bottle jack in their catalog a couple of months ago, and for a reasonable price too. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 23, 2008 Share Posted May 23, 2008 Dunsfold Land rovers in Surrey have brand new ex-rangie bottle jacks advertised for sale, and checking on my microcat the picture shows them to have the "V" thing on top to locate under an axle. £72 though!!! download the .csv list of their current stuff then search on the page for KAJ100610 )top left, "edit", then "find") Quote Link to comment Share on other sites More sharing options...
