The Hatt Posted May 23, 2008 Share Posted May 23, 2008 Who sells extended spring shackles for the Series motors? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted May 23, 2008 Share Posted May 23, 2008 Who sells extended spring shackles for the Series motors? As this is a query regarding Series vehicles I have moved it from the International forum into the Series forum. Please take the hint and post your questions in the appropriate area. While I'm here it would also be more polite to add a please or thank you - example: Can someone please tell me where I can buy extended spring shackles for Series motors? Who sells extended spring shackles for the Series motors? Many thanks. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 23, 2008 Share Posted May 23, 2008 Every LR parts place pretty much, also called 1-ton or military shackles. You'll need the bridge piece and bolt as well as the shackles. Quote Link to comment Share on other sites More sharing options...
The Hatt Posted May 23, 2008 Author Share Posted May 23, 2008 Every LR parts place pretty much, also called 1-ton or military shackles. You'll need the bridge piece and bolt as well as the shackles. thanks. I know CPC used to sell extended ones for about £65, are the 1 ton ones the same or are they shorter? Ta. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted May 25, 2008 Share Posted May 25, 2008 thanks.I know CPC used to sell extended ones for about £65, are the 1 ton ones the same or are they shorter? Ta. they were the same Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted May 25, 2008 Share Posted May 25, 2008 I might have some kicking about.... i'll see tomorrow.... Quote Link to comment Share on other sites More sharing options...
LRzed Posted May 26, 2008 Share Posted May 26, 2008 I know i've said it before. But.. I would get my spring shackles in front of the "from". People love to type extraneous words the end of their sentences at. That being said. they're an easy fab for any metal shop. get exactly what you need. I've used flat stock in the past. I have not checked out the LR shackles.. might not be the thing for them. But still Take yours to a machine shop or welder.. you can get what you need. Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted May 26, 2008 Share Posted May 26, 2008 I bought a set from Craddocks in the past. If you get your own made, don't forget the middle spacer if they are longer than standard. Cheers, Al. Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted May 26, 2008 Share Posted May 26, 2008 I bought a set from Craddocks in the past.If you get your own made, don't forget the middle spacer if they are longer than standard. Cheers, Al. Quote Link to comment Share on other sites More sharing options...
