Eduardo Posted June 3, 2008 Share Posted June 3, 2008 Hi Some days ago I discovered a crack in the rear door of my 110 SW Defender PUMA (just with 15.000 km) As you can see in the pictures, the crack comming from the window corner to the hinges side. I just spoke with the dealer and they said that its necessary an analysis to see what happens. By the way the door looks bended and does not close well in the upper part. Hinges are ok and do not show any damage Does anybody had the same problem in the past? Its a guarantee problem? I suspect that the weigth of the spare wheel is quite heavy to me supported by the door. Thanks in advance !!! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 3, 2008 Share Posted June 3, 2008 I don't see what there is to analyse. It's broken and should be fixed under warranty. I'd go bck and stamp my feet, the damage is obvious and will soon spread. Needs to be sorted ASAP. There is no damage on my 90 XS PUMA, yet. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted June 3, 2008 Share Posted June 3, 2008 Do you drive on bumpy roads/off road a lot Eduardo? That would make the spare jump about and cause the door to flex. I have an '04 but the door seems to be the same as on the newer ones. I use a 255/85 tyre so I will be keeping an eye on mine! Chris Quote Link to comment Share on other sites More sharing options...
TJ101 Posted June 3, 2008 Share Posted June 3, 2008 My 110 Puma also has a 255/85 BFG hanging off it,, no problem so far 100% warranty issue,, have a chat with your local dealer !! Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted June 3, 2008 Share Posted June 3, 2008 Not noticed that on mine. Quote Link to comment Share on other sites More sharing options...
alantd Posted June 3, 2008 Share Posted June 3, 2008 Not noticed anything either (will check again this evening though!). You've just convinced me to accelerate my swing-away wheel carrier though! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 3, 2008 Share Posted June 3, 2008 Not seen any door break there ever. The old ones crack around the carrier and on the new ones, the carrier itself cracks around the bolts that hold it to the door but the doors seem OK even on our roads here! Are you certain that somebody hasn't reversed into you because that is a classic way that back doors get broken and if it is just a gentle bump on the spare wheel it may not have left any trace... Quote Link to comment Share on other sites More sharing options...
JSG Posted June 3, 2008 Share Posted June 3, 2008 Agree with 100% warranty. I recall the older two piece rear doors giving up due the weight of the wheel and had to have mine repaired on the TD5 110 (pre 2002) but I'd not heard of problems with the one piece doors. Get the dealer to fix it and then fit a carrier - or fit the carrier first and get the new door fitted without the holder. Quote Link to comment Share on other sites More sharing options...
Eduardo Posted June 3, 2008 Author Share Posted June 3, 2008 Thanks to all, Today I went to the dealer and they have the same impression: guarantee issue due the weigth of the spare wheel. They took some photos to send it to LR. We will have a definitive answer on friday I hope. After that, for me, the carrier is a must and I will put it anyway together with the door repair. This is our family car and works almost 90% of the time in the city. The other 10% are some rougth roads but nothing too hard. Bogmonster: You have a point, but in this case I should notice some damages in the hinges, but its looks perfect. By the way, to bump in the wheel must be a truck or something quite high. Regards and thanks again! Eduardo Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 3, 2008 Share Posted June 3, 2008 Hey,,, there were no pictures...... Am I getting blind? Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 3, 2008 Share Posted June 3, 2008 It came up now sorry ED... Quote Link to comment Share on other sites More sharing options...
gemsbok Posted June 5, 2008 Share Posted June 5, 2008 Does anybody had the same problem in the past?Its a guarantee problem? I suspect that the weigth of the spare wheel is quite heavy to me supported by the door... Happily I have not had that problem. I did fit a swing away spare carrier at about 4,000kms because I thought some damage could result on the rough roads here (had hoped it might help with dust too, which it didn't). Would have thought it would be a straightforward warranty job. Ruaraidh Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 5, 2008 Share Posted June 5, 2008 Bogmonster: You have a point, but in this case I should notice some damages in the hinges, but its looks perfect. By the way, to bump in the wheel must be a truck or something quite high. Another Land Rover or reversing into a wall are probably the most common causes here! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 5, 2008 Share Posted June 5, 2008 Another Land Rover or reversing into a wall are probably the most common causes here! Surely to cause that much damage to the door by reversing into something or being reversed into, you would see some deforamtion to the rest of the door or have a broken window Quote Link to comment Share on other sites More sharing options...
Eduardo Posted June 5, 2008 Author Share Posted June 5, 2008 Surely to cause that much damage to the door by reversing into something or being reversed into, you would see some deforamtion to the rest of the door or have a broken window I'm 100% sure that was not a reversing in something and I don't believe that something hit the spare wheel (I checked again to see any damage in the wheel, but nothing appears). This door is used intensively by my 2 boys that are seated in the third row (may be one of the reason to have the problem early than others) By the way, cheking the papers of the 10.000 km inspection, I complain that the rear door doesn't close equally at the upper part than the lower part. At that time I believe that was a misadjustment problem but, due the hurry in recieve the car comming back, the dealer had not time to readjust the door. I thought that the door were bending along time until the aluminium doesn't resist making the crack. Anyway I will receive the answer tomorrow Regards Quote Link to comment Share on other sites More sharing options...
Eduardo Posted June 6, 2008 Author Share Posted June 6, 2008 Just to follow up. I receive today a call from the dealer... The cause of the failure is unknow but probably due a fatigue due a contamination in a welding point during the door assembly. The door will be replaced under guarantee by a new one, but I must wait 2 weeks (they don't have doors in stock ) Regards, Quote Link to comment Share on other sites More sharing options...
