bishbosh Posted June 9, 2008 Share Posted June 9, 2008 I have some somewhat blobby upside down and awkward spaces welds that I want to tidy up a bit before I paint. Can't get at them with the grinder and flap wheel. I know a die grinder is the right tool with a carbide burr but I don't have a compressor. All the electric die grinders I can find are silly money. So, anyone got any clever ideas? Is it worth trying something in an electric drill? What about a Dremmel or similar? I presume they wouldn't be up to the job? Thanks Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted June 9, 2008 Share Posted June 9, 2008 Dremels do a surprisingly good job of tidying up welds in awkward spots- obviously not as quick as an angle grinder but does the job... The other tool I use extensively for such things is an air file- I know you have no compressor and I am not sure that they do an equivalent electric one so looks like the dremel is your best bet. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 9, 2008 Share Posted June 9, 2008 These are a bit of cash, though you can probably find something cheaper, but they do work pretty well, especially with the coarse belts on them: http://shop.ccabrasives.com/black--decker-...a293e-711-p.asp Quote Link to comment Share on other sites More sharing options...
MogLite Posted June 9, 2008 Share Posted June 9, 2008 You'll be needing a Black & Decker Powerfile Works a treat, just dont use them side-side, cause then the belts fall off. Andy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 9, 2008 Share Posted June 9, 2008 I use a powerfile sometimes and they are quite good at getting in those pokey places. Les. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 9, 2008 Author Share Posted June 9, 2008 Thanks folks, the powerfile looks good! I have also just stumbled across THIS on the Blag. Any comments? Other than twice the price of the powerfile? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted June 9, 2008 Share Posted June 9, 2008 I don't have a compressor. Yes you do - mine! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 10, 2008 Author Share Posted June 10, 2008 Well, I got a powerfile today and gave it a blast. does just what I need so thanks for the recommendations! My only observation is that it has a prodigious appetite for belts! I'm off to eblag for a job lot! Quote Link to comment Share on other sites More sharing options...
simonr Posted June 11, 2008 Share Posted June 11, 2008 By coincidence - I've just bought a powerfile too! It's not arrived yet - but it sounds a good choice! I expect Les bought one for his toenails! Si Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 11, 2008 Share Posted June 11, 2008 At least I don't use an angle grinder to shave Les. Quote Link to comment Share on other sites More sharing options...
simonr Posted June 15, 2008 Share Posted June 15, 2008 Mine has arrived now. Having cleaned my teeth, I tried it on some ugly welds - and it did a fantastic job. Much better than a die grinder as the surface speed of the belt is higher. I would recommend them to anyone whose welding is occasionally untidy! (or has toenails like a gorilla) Si Quote Link to comment Share on other sites More sharing options...
