renault4 Posted July 3, 2008 Share Posted July 3, 2008 Although I have owned my defender for less than 12 months, I am getting a real feel for rusted nuts and bolts. After I have drilled out, ground out, hack-sawed out, chiselled out or just shouted out all the rusted nuts and bolts that I have had to remove, I was thinking what should I smother them with to prevent the same problem 10, 12, or 15 years down the line. some say copper grease but is a high melting point grease needed just to prevent corrosion? would a normal lithium grease do just as well? Quote Link to comment Share on other sites More sharing options...
western Posted July 3, 2008 Share Posted July 3, 2008 copaslip grease but used sparingly will be fine. Quote Link to comment Share on other sites More sharing options...
RichardAllen Posted July 3, 2008 Share Posted July 3, 2008 Although I have owned my defender for less than 12 months, I am getting a real feel for rusted nuts and bolts.After I have drilled out, ground out, hack-sawed out, chiselled out or just shouted out all the rusted nuts and bolts that I have had to remove, I was thinking what should I smother them with to prevent the same problem 10, 12, or 15 years down the line. some say copper grease but is a high melting point grease needed just to prevent corrosion? would a normal lithium grease do just as well? There is a view that if you need it to come apart use copperslip, if not use the right Loctite for the application Quote Link to comment Share on other sites More sharing options...
AD90 Posted July 3, 2008 Share Posted July 3, 2008 From a guy that works in a marine environment. Copper Grease and LOTS of it! At the risk of upsetting someone, apologies if I am not allowed to do this, this is my favourite http://www.kspaul.com/pbc1main.htm AD90 Quote Link to comment Share on other sites More sharing options...
muddy Posted July 3, 2008 Share Posted July 3, 2008 I daub everthing in coppaslip, never had a problem yet. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 4, 2008 Share Posted July 4, 2008 I have found a tread sealant better than copper grease. The thread sealant does just that, seals the threads. I do copper grease bolt shanks at the same time. mike Quote Link to comment Share on other sites More sharing options...
tychoS Posted July 5, 2008 Share Posted July 5, 2008 Although I have owned my defender for less than 12 months, I am getting a real feel for rusted nuts and bolts.After I have drilled out, ground out, hack-sawed out, chiselled out or just shouted out all the rusted nuts and bolts that I have had to remove, I was thinking what should I smother them with to prevent the same problem 10, 12, or 15 years down the line. some say copper grease but is a high melting point grease needed just to prevent corrosion? would a normal lithium grease do just as well? What do you use for undoing rusted bolts? Aerosol rust dissolver works in most cases. Only nuts on the axles and the like that are constantly sprayed in salty water during winter have a right to be removed using saws, drills, heat and the like ;-) Quote Link to comment Share on other sites More sharing options...
