need4speed Posted July 4, 2008 Share Posted July 4, 2008 Just watched 'A 4x4 is born' the other night and would like to know who sells the variable valve timing set he used. I know he used a Kent cam kit but dont know if they produced the timing gear set? Anyone know? Quote Link to comment Share on other sites More sharing options...
markt Posted July 4, 2008 Share Posted July 4, 2008 Try RPI http://www.rpiv8.com/engine-6b.htm Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 4, 2008 Author Share Posted July 4, 2008 thanks but thats not it. the set that mark used had 4 allen bolts on the front which made it completely adjustable... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 4, 2008 Share Posted July 4, 2008 ...make it adjustable and they will adjust it wrong -- look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver.Colin Chapman Try Real Steel, but I'm reminded of the vernier timing set fitted to Nige's V8 which is welded up - he asked Mr Eales why it was welded in place and the response was "To stop people like you fiddling with it" Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 4, 2008 Author Share Posted July 4, 2008 thanks fridge. ive looked in rs website and cant see it but il try calling them... Quote Link to comment Share on other sites More sharing options...
markt Posted July 4, 2008 Share Posted July 4, 2008 http://www.rimmerbros.co.uk:80/rimmer/rove...ft%20Components http://www.rimmerbros.co.uk:80/cgi-bin/rim...ngine/cam-chain fully adjustable, at a nice price though !! Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 4, 2008 Author Share Posted July 4, 2008 that sounds like the one. thanks for that link fella.... Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted July 4, 2008 Share Posted July 4, 2008 I guess you will end up using the zero degrees with reference to the crankshaft rather than have the cam off set by +/- up to 3 degrees ................. any more than that and you will start to run into 'issues' I have considered this carefully in the past from both the technical and practical standpoint ................. it didn’t take me long to reach the conclusion that for our off road type use that the standard cam timing way superior in lots of ways . You could advance the cam to give you a bit more low down torque but then lose it at the top end ............ or retard the cam and get all the torque / power in the higher rev band, but you lose out at the bottom end.............. The real gains are to be made at the top end when the engine has been extensively modified. I decided that the adjustable timing sets were of much more use the circuit and strip racing guys when you tend to hit the rpm 'sweet spot' and stay there.................. I would go for the cloyes timing set................ as well as zero timing, it has offset keyways if you want +4 or -4 (remeber the cam turns at half engine speed so that equates to camshaft +/- 2 degrees. There is more info about dialling in the cam in my engine build (tech archive). If you want a head ache then look here............http://www.compcams.com/technical/TimingTutorial/ Cloyes..................http://www.cloyes.com/HighPerformance/Perf...US/Default.aspx Ian Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 4, 2008 Share Posted July 4, 2008 Try Real Steel, but I'm reminded of the vernier timing set fitted to Nige's V8 which is welded up - he asked Mr Eales why it was welded in place and the response was "To stop people like you fiddling with it" Tis true every word And for the right reasons. Unless you have something very very exotic - why on earth do you want this (unneeded) complexity ? Nige Quote Link to comment Share on other sites More sharing options...
