mudmuncher Posted August 15, 2008 Share Posted August 15, 2008 Hi all I need a bit of advise here please. I have a series 3 with the orignal series 3 temp guage in the dash, i have fitted a 200tdi engine and have a 200 tdi temp sender in the head this is not reading correct with the series guage as the engine seams to get very hot very quick !!! I know the senders have different threads i can get over this problem but my question is what sender should i use in the engine to match to the series temp guage ?? 2.5 N/A / 2.5TD ???? Many thanks chris Quote Link to comment Share on other sites More sharing options...
kingdong Posted August 15, 2008 Share Posted August 15, 2008 Hi mudmuncher i am doing the same conversion on a s2a swb and i am going to use the sender unit and adapter from the series engine so it is compatable with the temp guage cheers graham. 1962 s11a swb. was a 2. 1/4 petrol now its a 200 tdi Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 16, 2008 Share Posted August 16, 2008 The sender has to match the guage, so series sender and a series guage. Les. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted August 16, 2008 Share Posted August 16, 2008 The sender has to match the guage, so series sender and a series guage.Les. Does the 2.5naturally asthmatic and turdo diesel run at 82 degrees like a 2.25 pet? if so will the gauge not always run high up the scale, as the tdi runs at slightly higher 88 degrees? I suppose you correct this with a different voltage regulator Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 16, 2008 Share Posted August 16, 2008 It's not the thermostat/running temperature that's the problem, it's how the guage and sender relate to each other. Series motors have a little regulator for the fuel and temp, but I believe it's a lot more complicated with later models. Les. Quote Link to comment Share on other sites More sharing options...
RobotMan Posted August 16, 2008 Share Posted August 16, 2008 I use original sender and gauge with a imperial to metric home made adaptor. Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted August 16, 2008 Author Share Posted August 16, 2008 Robotman this is what i am going to do series guage and series sender Do you find that the guage is always running or showing hot ??? Cheers chris Quote Link to comment Share on other sites More sharing options...
88inchthing Posted August 16, 2008 Share Posted August 16, 2008 Hi All I am new to this forum so please be gentle. I used the series sender and an adapter from a 2.5 petrol.I find the gauge reads correct, but as stated above the TDI runs a little warmer.Just have to get used to the needle sitting at three quarters. Hope this helps. Bill Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 17, 2008 Share Posted August 17, 2008 Hi AllI am new to this forum so please be gentle. I used the series sender and an adapter from a 2.5 petrol.I find the gauge reads correct, but as stated above the TDI runs a little warmer.Just have to get used to the needle sitting at three quarters. Hope this helps. Bill Exactly what I use, however I replaced the naff votlage regulator thingy with a 9v voltage regulator to drop the reading on the gauge slightly. Mine now sits nicely in the middle at normal running temp. Jon Quote Link to comment Share on other sites More sharing options...
