rustymark Posted August 22, 2009 Author Share Posted August 22, 2009 hi as far as i am aware yes but there is a small plastic lug that needs a cut out making in the new part. no major hassle pends how confident you feel modifying it Quote Link to comment Share on other sites More sharing options...
LR NUT Posted August 23, 2009 Share Posted August 23, 2009 hi as far as i am aware yes but there is a small plastic lug that needs a cut out making in the new part. no major hassle pends how confident you feel modifying it ok thanks a lot Bud will be ordering the conversion this week Quote Link to comment Share on other sites More sharing options...
crusty jim Posted October 20, 2009 Share Posted October 20, 2009 Any update on this conversion ? I have a 2005 TD4 that needs a new breather. I`m in two minds which one to go for ? Any details on the mod required to fit the BMW part to the later engines ? Quote Link to comment Share on other sites More sharing options...
Mockery Posted October 21, 2009 Share Posted October 21, 2009 I got the BMW part sent to me and stuck it in a few months ago. It was a straight swap and there were no modifications required as far as I could see. (2005 TD4) Quote Link to comment Share on other sites More sharing options...
pugwash Posted December 31, 2009 Share Posted December 31, 2009 Oddly enough came across this thread whilst researchig the breather problem for my 3 series beemer. Can confirm that the new breather is of a far better design and well worth fitting, shouldn't ever clog up again. Another very common problem with 320d and 330d BMW engines is the EGR getting totally gunked with sooty deposits- might be worth checking on TD4 if its not a known problem already. Quote Link to comment Share on other sites More sharing options...
Broad Oak BMW Posted February 11, 2010 Share Posted February 11, 2010 Hi all Am new here. Forgive the blatant self-promotion, but one of our customers told me about the breather for his BMW that is also fitted to LandRovers. A quick search on Google lead me here ! I thought I would offer the breather part # 11127799224 at a discounted price... that way both you and I profit ! So if you need one the price is £40.42 which is 10% off AND we'll post it for FREE ! I have put these on ebay and mentioned this site: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200438014177&ssPageName=STRK:MESELX:IT Please only use this filter if you know it is OK to do so - We are not Land Rover people ! Thanks for listening ! Quote Link to comment Share on other sites More sharing options...
OlasMC Posted February 11, 2010 Share Posted February 11, 2010 ok as promised photos of old landrover part and new bmw modification - along with part numbers. approx cost £36 brand new - about the same as the filter alone - kit comes with all new rubber seals. Please note this is NOT a Landrover dealer part - it is the same part as fitted to the same engine in 3 series BMWs! And... its oily as i wanted to make sure it worked fine BEFORE i posted and you all rush out, buy it, fit it and then go bang and blame me! Hi Have you another photos from top? You means that the usual td4 filter can be directly replaced by this one? And after that you can put back the cover engine? Thanks Quote Link to comment Share on other sites More sharing options...
Broad Oak BMW Posted February 12, 2010 Share Posted February 12, 2010 OlasMC, We have a photo of the breather here: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200438014177&ssPageName=STRK:MESELX:IT Quote Link to comment Share on other sites More sharing options...
OlasMC Posted February 18, 2010 Share Posted February 18, 2010 OlasMC, We have a photo of the breather here: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200438014177&ssPageName=STRK:MESELX:IT Last weekend I did a test with the old installed filter. It was removed and cleaned with a specific gel. It was totally covered by oil!! The enclosure and the rubber gasket were was also clean. Then, after dry all parts I reinstall all back. I realize some strange noise when turbo starts to run, like a leakage pressure. I removed again everything and I noticed a problem in the gasket. Because I hadn't new gaskets, I decided to put a special insulation product, together with the old gasket, like a high temperatures red silicone that normally is used in this kind of works. Know it it OK and the behavior of the engine is more silent and has a better response. I noticed that the breather filter case has only four screws that if my opinion in not sufficient when new gaskets are not available. I will run some kilometers and I will see the results. After that I'm thinking to change for the BMW part. Just one question, the BMW breather filter has a filter itself or it some different thing? How can it breathe and separate the oil? Thanks Quote Link to comment Share on other sites More sharing options...
g7wgx Posted May 25, 2010 Share Posted May 25, 2010 hello i am thinking of fitting this part will it fit vin number SALLNABE15A454363 as i dont no much about landys my first one m0say Quote Link to comment Share on other sites More sharing options...
Bish789 Posted May 25, 2010 Share Posted May 25, 2010 Hi everyone. You don't need to buy the full part at £42.00. I bought the cyclone part yesterday at Williams BMW in Manchester. Cost of £21.60. Part no. B11.12.7.799.367. Came with cyclone part, o ring for bottom of cyclone, and two new seals for unit. Fitted last night. Easy enough job. just replaces old filter. This is the same price as the sponge filter. No contest. Independant BMW mechanic who was in parts dept. said this is the only bit they fit. Hope this helps. Quote Link to comment Share on other sites More sharing options...
g7wgx Posted May 27, 2010 Share Posted May 27, 2010 hello i am thinking of fitting this part will it fit vin number SALLNABE15A454363 as i dont no much about landys my first one m0say hi i have now fitted the conversion and there is no modes to do just replace old for new fits great it is a easy job so have a go i dont no any thing about land rovers but thought why not have agon so i did dave. Quote Link to comment Share on other sites More sharing options...
g7wgx Posted May 27, 2010 Share Posted May 27, 2010 Hi everyone. You don't need to buy the full part at £42.00. I bought the cyclone part yesterday at Williams BMW in Manchester. Cost of £21.60. Part no. B11.12.7.799.367. Came with cyclone part, o ring for bottom of cyclone, and two new seals for unit. Fitted last night. Easy enough job. just replaces old filter. This is the same price as the sponge filter. No contest. Independant BMW mechanic who was in parts dept. said this is the only bit they fit. Hope this helps. hi you have to buy the full kit as it will not fit Quote Link to comment Share on other sites More sharing options...
g7wgx Posted May 28, 2010 Share Posted May 28, 2010 Crankcase filter was due for a change on my TD4 so i thought better do it as doubt it had ever been changed in its life. Shopped around for a bit and it turns out that BMW are aware failure of the filter ( ie blocked) will cause pressurisation in the engine and blow oil through turbo / back up dipstick tube. They have produced a modified filter housing. I will post some pics on here. Fitted the mod kit tonight and it works a charm - it no longer has the filter but has a plastic insert with what looks like 2 cones in it. Weird but effective - there is nothing to block so no problems! hi i have just fitted the new filter do you no the life of this new filter ie any miles years before a renew thanks dave Quote Link to comment Share on other sites More sharing options...
g7wgx Posted May 28, 2010 Share Posted May 28, 2010 hi you have to buy the full kit as it will not fit sorry you are right it will fit just checked Quote Link to comment Share on other sites More sharing options...
g7wgx Posted May 28, 2010 Share Posted May 28, 2010 Crankcase filter was due for a change on my TD4 so i thought better do it as doubt it had ever been changed in its life. Shopped around for a bit and it turns out that BMW are aware failure of the filter ( ie blocked) will cause pressurisation in the engine and blow oil through turbo / back up dipstick tube. They have produced a modified filter housing. I will post some pics on here. Fitted the mod kit tonight and it works a charm - it no longer has the filter but has a plastic insert with what looks like 2 cones in it. Weird but effective - there is nothing to block so no problems! i have bought and fitted the new one but in the old one there is a rubber oring and in the new one there is not is this how it should be please help dave Quote Link to comment Share on other sites More sharing options...
Bish789 Posted May 30, 2010 Share Posted May 30, 2010 Dave If you have bought just the cyclone filter from BMW to replace the sponge filter, then there should be one O ring and two seals with tabs on for the housing. Should be the same for the complete unit as well. Paul Quote Link to comment Share on other sites More sharing options...
g7wgx Posted June 1, 2010 Share Posted June 1, 2010 Dave If you have bought just the cyclone filter from BMW to replace the sponge filter, then there should be one O ring and two seals with tabs on for the housing. Should be the same for the complete unit as well. Paul yes your right paul thanks,any idears how long the new cyclone lasts thanks dave Quote Link to comment Share on other sites More sharing options...
Bish789 Posted June 2, 2010 Share Posted June 2, 2010 yes your right paul thanks,any idears how long the new cyclone lasts thanks dave According to what I can find out, for ever! Still worth a check though. Looks like it can be took apart, so when i've got the courage, may split it to find out. Could be that it could be cleaned with carb cleaner or WD, so theoretically it ould last for ever. Quote Link to comment Share on other sites More sharing options...
rustymark Posted June 20, 2010 Author Share Posted June 20, 2010 Wow Been a couple of years (nearly) since i started this thread. never thought 10500 hits would be possible - thats a lot of TD4 owners! how has everyones TD4 been since changing? Mines still behaving itself and doing as it should. Mark Quote Link to comment Share on other sites More sharing options...
digiboy Posted June 21, 2010 Share Posted June 21, 2010 I have a 2002 TD4 commercial 115k miles. Did the mod a couple of weeks ago along with cleaning the EGR. I can report a lot smoother engine and better MPG, got almost 40mpg out of it the last tankfull!! The only thing I had to do to fit the filter was to file a new groove in it as there is a plastic location tab in a different place in the engine. 2min job. I can also reccomend Broad Oak via the Ebay link above. Ordered it late Sunday night - arrived Tuesday morning! Phil. Quote Link to comment Share on other sites More sharing options...
Broad Oak BMW Posted July 2, 2010 Share Posted July 2, 2010 Hi all. Glad you are pleased with the service. We are selling quite a few of these. Makes me wonder what else is the same....! As I said originally, we are not Landie delaers so I need you guys to tell me what BMW parts you want for your TD4 ! And we will do you a deal Thanks. Quote Link to comment Share on other sites More sharing options...
silkwood Posted July 17, 2010 Share Posted July 17, 2010 Hello people, Because of this forum and others. Yesterday I've changed the crankcase filter for the BMW Filter. I share some pics with you: First take a Freelander. This is the BMW part with number 11127799224. Around euro 40,--. Sorry I'm Dutch This is how the Land Rover Filter looked. I drove about 60.000km with it, but I don't know if it was changed before. The car is from 2005, I have it sinds 2008 and drove 60.000km with it. The diffrence between the Land Rover filter and the BMW filter. It was not neccessary to make an adjustment to place the filter in my 2005 Td4. Quote Link to comment Share on other sites More sharing options...
Broad Oak BMW Posted September 23, 2010 Share Posted September 23, 2010 Hi. Still reading this thread with great interest ! We can supply just the cyclone filter part, still BMW if req'd. Does this breather also fit Range Rover TD6 ? Cheers ! Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted September 25, 2010 Share Posted September 25, 2010 It is a TDV6 in the range rover Quote Link to comment Share on other sites More sharing options...
