Peter Posted January 14, 2006 Share Posted January 14, 2006 Probably, best place to ask this question: Got a pair of Wolf doors. Need to know what shut latch I need for them on a civilian 90. Does anyone know if these are the same as those found on regular Series 2 / 3 ones ? Quote Link to comment Share on other sites More sharing options...
dasterdly Posted January 15, 2006 Share Posted January 15, 2006 Probably, best place to ask this question:Got a pair of Wolf doors. Need to know what shut latch I need for them on a civilian 90. Does anyone know if these are the same as those found on regular Series 2 / 3 ones ? hello, what exactly is your defination of " wolf doors " ? i bought new series 3 door bottoms,and fitted the early 90/110/military ally door tops. i then fitted the normal lift up handle lock, and slam striker, some people prefer the anti burst locks and striker. i chose the series type slam striker simply because i was always hooking myself on the normal defender striker, which sticks out. cheers... Quote Link to comment Share on other sites More sharing options...
Peter Posted January 16, 2006 Author Share Posted January 16, 2006 hello,what exactly is your defination of " wolf doors " ? i bought new series 3 door bottoms,and fitted the early 90/110/military ally door tops. i then fitted the normal lift up handle lock, and slam striker, some people prefer the anti burst locks and striker. i chose the series type slam striker simply because i was always hooking myself on the normal defender striker, which sticks out. cheers... Thanks, I think they are the same as standard Series 3 stock, simply as they are cheap, work and easy to fix. Got fed up with the standard defender doors not being strong enough, might miss the winding window though. Cheers Peter Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 16, 2006 Share Posted January 16, 2006 Yup, they're same as S3 anti bust type locks, and NAS type doors too. Think it'll be "Striker-door lock, MUC2959" and you can have "Shroud, central door lock, LH & RH MUC4203 & MUC4202" to stop you catching your jeans on them when you get in and out! Quote Link to comment Share on other sites More sharing options...
Peter Posted January 17, 2006 Author Share Posted January 17, 2006 Yup, they're same as S3 anti bust type locks, and NAS type doors too.Think it'll be "Striker-door lock, MUC2959" and you can have "Shroud, central door lock, LH & RH MUC4203 & MUC4202" to stop you catching your jeans on them when you get in and out! Brilliant, thanks Jim. Peter. Quote Link to comment Share on other sites More sharing options...
JST Posted March 13, 2006 Share Posted March 13, 2006 you can fit either striker or anti burst latches and catches. i went for the series slam type for the simplicity, cost £12 a door, and ease. Quote Link to comment Share on other sites More sharing options...
oneten110 Posted April 3, 2006 Share Posted April 3, 2006 In reply to Got fed up with the standard defender doors not being strong enough, might miss the winding window though. The push button doors are MUCH stronger than anything that preceded them. The 2 piece doors on my aged oneten flex quite noticably when doing about 70 mph, a problem I never had with pushbutton doors. The two piece doors also let a lot more draughts wind noise and general road noise into the driving compartment. Err all of that said, I still prefer the sliding windows. Quote Link to comment Share on other sites More sharing options...
Michele Posted July 7, 2006 Share Posted July 7, 2006 It's just to let you fully enjoy the natural environment. It's a bonus! The two piece doors also let a lot more draughts wind noise and general road noise into the driving compartment. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 10, 2006 Share Posted July 10, 2006 and the main problem with the push button handles they seem to latch on to tree's much easier In reply toGot fed up with the standard defender doors not being strong enough, might miss the winding window though. The push button doors are MUCH stronger than anything that preceded them. The 2 piece doors on my aged oneten flex quite noticably when doing about 70 mph, a problem I never had with pushbutton doors. The two piece doors also let a lot more draughts wind noise and general road noise into the driving compartment. Err all of that said, I still prefer the sliding windows. Quote Link to comment Share on other sites More sharing options...
orange rover Posted July 30, 2009 Share Posted July 30, 2009 Yup, they're same as S3 anti bust type locks, and NAS type doors too.Think it'll be "Striker-door lock, MUC2959" and you can have "Shroud, central door lock, LH & RH MUC4203 & MUC4202" to stop you catching your jeans on them when you get in and out! bringing this up again - anyone knows the number for the anti burst door locks? cheers spec Quote Link to comment Share on other sites More sharing options...
