Guest DiscoTD4 Posted September 3, 2008 Share Posted September 3, 2008 Hi - seems quite a few people have successfully removed the cat with positive results. Has anyone performed major surgery on the cat after de-cating, I'm interested to see what's actually inside these things. Cheers Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted September 3, 2008 Share Posted September 3, 2008 platinum thats worth lots of pennies Quote Link to comment Share on other sites More sharing options...
Muther Trucker Posted September 3, 2008 Share Posted September 3, 2008 ^^^ thats all you need to know... i can get £150 a cat round here.... Quote Link to comment Share on other sites More sharing options...
dougstar Posted September 4, 2008 Share Posted September 4, 2008 ^^^ thats all you need to know... i can get £150 a cat round here.... jeeeees thats a good price i was only getting around 30 for a standard one i also got ripped off with a cat i got from work out of a pertrol vapour recorvy unit that stood 800mm tall 300 in the centre and got just 70 for that one o an my neighbour watched some pikies nick thelast one i had off my driveway!! think ill pop over and see you next time u got my hands on one Dougie Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted September 4, 2008 Share Posted September 4, 2008 Not the best photo's but they show the inside of the cat off my 300TDi. Pete. Quote Link to comment Share on other sites More sharing options...
Escape Posted September 4, 2008 Share Posted September 4, 2008 This is what came out of my V8: Quote Link to comment Share on other sites More sharing options...
Muther Trucker Posted September 4, 2008 Share Posted September 4, 2008 ^^^ thats all you need to know... i can get £150 a cat round here.... sorry, typo - should have been £50 a cat.... Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted September 4, 2008 Share Posted September 4, 2008 thank's for taking the time to upload the photo's. amazing it looks like some sort of mesh - I'm not surprised de-cating makes a difference, blimey Quote Link to comment Share on other sites More sharing options...
Escape Posted September 4, 2008 Share Posted September 4, 2008 thank's for taking the time to upload the photo's. amazingit looks like some sort of mesh - I'm not surprised de-cating makes a difference, blimey It's indeed some sort of mesh, to increase the active surface. Each cat held 2 blocks, on the left side one was broken up, causing the airflow to be reduced significantly which caused the cat to overheat and the insulation to catch fire! You can see in the pictures the bottom right one is also badly cracked, I'm sure it wouldn't have laste duch longer. Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted September 4, 2008 Share Posted September 4, 2008 Does this mean that folk are starting to come round to the fact that it IS a cat not a particle filter? Quote Link to comment Share on other sites More sharing options...
mscowley Posted September 4, 2008 Share Posted September 4, 2008 I have blanked the egr valve and thought about putting a d cat pipe on my disco but wondering will it still go through a mot or not. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted September 4, 2008 Share Posted September 4, 2008 I have blanked the egr valve and thought about putting a d cat pipe on my disco but wondering will it still go through a mot or not. There is no requirement for a Cat on a diesel in the MOT. as long as it passes the smoke test it will be fine. Mines been tested twice since I changed mine passed both times no problems. Pete, Quote Link to comment Share on other sites More sharing options...
k9unit Posted September 7, 2008 Share Posted September 7, 2008 who do u sell the cats to Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted September 7, 2008 Share Posted September 7, 2008 who do u sell the cats toyou can sell to any reputable scrap metal or precious metal merchant. I got £50 for a fairly small one off a pug 406 the other week and £150/ton for the car and rubbish thrown in it! Bloke looked in the cat, cos apparantly the pikeys can remove the platinum and inside...haha Quote Link to comment Share on other sites More sharing options...
ahebron Posted September 16, 2008 Share Posted September 16, 2008 I don't think the "Cat" for TDi's is a catalytic converter like found on petrol engines. It is called a particulate filter which I believe is just fine mesh that traps the soot from burnt diesel. Removing this makes the engine breath freer. I had the particulate filter removed and have just had the rear box removed as it was rusting out the back from the exhaust on my 300TDi. Not much extra noise. Just running the standard centre box. Adrian Quote Link to comment Share on other sites More sharing options...
asdj45 Posted September 17, 2008 Share Posted September 17, 2008 I don't think the "Cat" for TDi's is a catalytic converter like found on petrol engines.It is called a particulate filter which I believe is just fine mesh that traps the soot from burnt diesel. Removing this makes the engine breath freer. I had the particulate filter removed and have just had the rear box removed as it was rusting out the back from the exhaust on my 300TDi. Not much extra noise. Just running the standard centre box. Adrian I know what was in my 300 TDI auto version and that was a lot of black stuff that prevented my Disco from perfroming whislt towing etc.. - I ordered a straight through down pipe from ATS (probably not the cheapest way of doing it) but they would not fit customer parts anyway. The Disco now performs very well and being an auto does not tend to cut into overdrive so quickly - it seems much smoother and quieter! no more black smoke on kick down either. Regards Andy Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted September 17, 2008 Share Posted September 17, 2008 I don't think the "Cat" for TDi's is a catalytic converter like found on petrol engines.It is called a particulate filter which I believe is just fine mesh that traps the soot from burnt diesel. Removing this makes the engine breath freer. I had the particulate filter removed and have just had the rear box removed as it was rusting out the back from the exhaust on my 300TDi. Not much extra noise. Just running the standard centre box. Adrian Interesting point, the workshop manual refer to this as a cat and also the service schedule refer to replacing the cat at 10 years, so are we saying it's not a cat but a PDF ? I'm confused now Regards Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted September 17, 2008 Share Posted September 17, 2008 NO! - its a single stage catalytic converter - Particulate filters were for commercial use only when the 300 TDi came out due to the size, complexity and cost of the things. The only reliable set-up to date on a car sized vehicle is the one used by Pugeot - it needs stuff like a fuel injector which actually sets the insides on fire to burn off the soot every now and then (simplisticaly put) - NOT something which is fitted to ANY LR. You have a Cat, full stop. Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted September 18, 2008 Share Posted September 18, 2008 cheers for the clarification. Quote Link to comment Share on other sites More sharing options...
