Mo Murphy Posted January 22, 2006 Share Posted January 22, 2006 Can I mount my albright solenoid upside down ? I've moved it to make room for the second washer bottle and it's quite close to the bonnet now. Turning it upside down would give plenty of clearance. Does anyone else have theirs upside down ? Mo Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted January 22, 2006 Share Posted January 22, 2006 What is the second washer bottle used for? Quote Link to comment Share on other sites More sharing options...
MogLite Posted January 22, 2006 Share Posted January 22, 2006 ISTR that you aren't supposed to mount them upside down. Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 (edited) Mines mounted on it's side in behind the LH headlight on top of the galvy wheelarch, the mounting info is here Tech Archive note bottom centre says horizontal or vertical But connections Must be on top, I assume so the solenoids work correctly. Edited January 22, 2006 by western Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 22, 2006 Author Share Posted January 22, 2006 Thanks Chaps, The answer is no then. Ralph, behind the lh headlamp is a good place to put the solenoid but only if there isn't a large under wing washer bottle there already Ben, strangely I'm using it for washer water It feeds tubes that run to the wiper blades. Cheers Mo Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted January 22, 2006 Share Posted January 22, 2006 Ben, strangely I'm using it for washer water It feeds tubes that run to the wiper blades.Cheers Mo So why two then? Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 Thanks Chaps, The answer is no then.Ralph, behind the lh headlamp is a good place to put the solenoid but only if there isn't a large under wing washer bottle there already Ben, strangely I'm using it for washer water It feeds tubes that run to the wiper blades. Cheers Mo OK, I'll give you that my 110 has he single double pump bottle further back, So I guess the first bottle is just feeding the second one to increase your wash capacity ?? Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 22, 2006 Share Posted January 22, 2006 Mo, thow about mounting them in a waterproof junction box? That way if they're close to the bonnet there's no issues with it shorting. Annother wiper mod I'm going to do soon is to use Discovery headlight washer jets in place of the usual jets. A guy in the Shire's has done it on his Tomcat and it works unbelievably well. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 22, 2006 Share Posted January 22, 2006 Annother wiper mod I'm going to do soon is to use Discovery headlight washer jets in place of the usual jets. A guy in the Shire's has done it on his Tomcat and it works unbelievably well. Work best if you use a RR/Disco washer bottle with the headlight washer pump on it. the headlight washer pump is bigger and designed to shift more water. Plus you still have the two (front and rear) standard washer pumps if you want to pipe up additional jets. Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 Mo, thow about mounting them in a waterproof junction box? That way if they're close to the bonnet there's no issues with it shorting.Annother wiper mod I'm going to do soon is to use Discovery headlight washer jets in place of the usual jets. A guy in the Shire's has done it on his Tomcat and it works unbelievably well. I've rerouted the wash pipes to feed 2 of the later 2hole nozzles, so now instead of just 2 jets in the middle of the screen I have 2 directly infront of driver & passenger. works a treat with the normal pump. all using existing parts & holes in the bulkhead. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 22, 2006 Author Share Posted January 22, 2006 Will, I'll just have to get off my lazy bum and make a bracket to drop the solenoid a bit I'm using a standard under wing bottle for the standard jets on the front and rear and a engine bay mounted single bottle to feed two bright blue hoses going to the end of the wipers. Seems to work quite well. It's one of those "I've got no money at the moment for toys so I'll do one of those many jobs on the list" type jobs I'll post a pic if anyone is bored enough to look at it Mo Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 I'll post a pic if anyone is bored enough to look at it Write it up & it can go in the tekky archives Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 22, 2006 Author Share Posted January 22, 2006 Not sure about the write up bit Ralph ! But heres a couple of pics Mo Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 Looks like a good mod. see what you mean about the solly pack now Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 22, 2006 Share Posted January 22, 2006 Not sure about the write up bit Ralph !But heres a couple of pics Mo Nice job, Mo. I've just spent the day putting on new Albrights for the rear winch and finishing the front setup. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 22, 2006 Author Share Posted January 22, 2006 Thanks lads, it's just a shame PetSmart only have blue tube Mo Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 Thanks lads, it's just a shame PetSmart only have blue tube Mo Some poor hamster got no water feed tube now after green I suppose to colour co-ord with the paint work Quote Link to comment Share on other sites More sharing options...
