landmannnn Posted October 13, 2008 Share Posted October 13, 2008 I have nearly got my lr down to the rolling chassis. So then I need to swap all the bits onto my "new" chassis. What is simplest way to do this? I was thinking either: 1. remove suspension and lower so that engine and box are on the ground, lift chassis over the engine and then lift new chassis over engine, jack it up and replace suspension 2. split engine and gearbox, hire engine crane, lift engine out, swap suspension then crane engine back in Any other methods? (The old chassis is scrap so will be chopped up) Mike Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 14, 2008 Share Posted October 14, 2008 Usually it's engine and gearbox out of the way, attach axles to new chassis, then engine/gearbox in. I should imagine jacking the engine and gearbox into place from the ground would be very difficult to do. I suppose you could place the chassis on the ground, then position the engine and box, then jack the whole lot up to attach the axles. Just a different way of doing it I suppose. Les. Quote Link to comment Share on other sites More sharing options...
nickm Posted October 14, 2008 Share Posted October 14, 2008 could be worth sticking a new clutch in while it's apart or atleast having a look at yours easier to split when there on the floor Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 14, 2008 Share Posted October 14, 2008 I'd take the axles/suspension off the old chassis, leave it on blocks, fit the axles/suspension to the new chassis, then crane the engine/boxes across. That way you avoid having the engine sat on its sump, or rolling around on the floor. Quote Link to comment Share on other sites More sharing options...
sotal Posted October 14, 2008 Share Posted October 14, 2008 Last one I helped with, we.. Took Gear box off put two railway sleepers underneath the engine Removed front axle and lowered engine down onto the wood Removed rear axle Chopped up rotten chassis and discarded Lifted new chassis over engine Fiddled about to get it to the right place, and managed to get the engine bolted in, jacked the rear and attached axle jacked the front and attached axle replaced clutch replaced gearbox etc Did the job perfectly well, fairly quickly and didn't require any engine cranes or other equipment that we didn't have to hand, putting the body on in one go (complete with bulkhead) was interesting and not quite so easy by hand Quote Link to comment Share on other sites More sharing options...
JST Posted October 14, 2008 Share Posted October 14, 2008 i would hire an engine crane and do it in the order Les suggested and your option2 Quote Link to comment Share on other sites More sharing options...
landmannnn Posted October 14, 2008 Author Share Posted October 14, 2008 Thanks guys, I was looking for an easy way that did not involve splitting the engine and box. Thinking about it I suppose if the body is off then that isn't really too much extra work. Quote Link to comment Share on other sites More sharing options...
discojmz Posted October 14, 2008 Share Posted October 14, 2008 take one engine crane, lift engine and boxes complete, set aside swap axles, suspension etc over to new chassis lift engine and boxes, still complete, onto new rolling chassis job jobbed just like Les said Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 15, 2008 Share Posted October 15, 2008 Any of the above though my prefference is with a crane. Whatever you do unless the clutch was changed recently I would split the box and engine to change the clutch now rather than later. I did not change my clutch last time just the release bearing and now I have to pull it apart again to replace the clutch as well. Doh. Marc Quote Link to comment Share on other sites More sharing options...
